Canning on the sensitemp burner
Thanks TomTurbomatic,
You answered my question. I am using an All American canner 930, a double stack that I had only used once so the bottom is perfectly flat. They are built like a MAC truck and you have to really do something seriously bad to warp them. The problem was that I was afraid to turn the temp up that high as the book that came with the stove said to put it on high to begin with then adjust down for canning. This is standard for using a pressure canner anyway, but it wasn’t high enough to build enough pressure in the beginning. I did turn it to 400; I was afraid to go any higher as I’m that familiar with this stove, and it really helped get it going. As soon as the pressure gauge started moving I turned it back to high. After the first batch was finished, it seemed like the other 2 batches came quickly up to speed. I’m thinking that was because the canner itself was still quite warm after it was emptied and re-loaded with another batch of jars.
Thanks again for your help.
