Kraut
We use the big crock to make ours but can use a food grade bucket or plastic trash can or put up in wide mouth quart jars.
Recipe to use
Cut the cabbage in half and take the core out. Shred with a knife in thin slices. For every 5 pounds of cabbage add 3 tablespoons of canning salt. Mix well and then put in one of the above and tightly pack down (we use a metal potato masher along with a wooden tamper from our cone sieve) pack it tight until liquid starts to flow. We normally do about 50 to 80 pounds of cabbage. To shred ours we now use our electric slicer. Two people can do it but 3 or more are better as your hands and arms can get sore.
Once all the cabbage is packed tightly in the crock or bucket or quart jars the liquid should cover the top.
On a crock or bucket use a plate or glass pie pan that just pits the opening. Weigh this down with a brick wrapped in plastic bag or use a gallon or gallon and a half freezer bag filled with water and some canning salt. (the salt is just incase the bag leaks so won't dilute your salt for the fermentation) Cover with a clean white kitchen towel and set in an out of the way area. Each day check for scum on the top and take off with a plastic or stainless steel spoon and if liquid has gone down add more salt water. If the towel is damp rinse in hot water and place back on top. Depending on the room tempature it will take 4 to 6 weeks to ferment. You can tell by it not bubbling and also the smell which is not bad. At this point you can leave in the crock and pull out and use as needed always cook 15 minutes before eating, pack in freezer bags and freeze then cook the same as for fresh or take out and put in large pot and bring to a boil and pack in wide mouth quart jars and process for 20 minutes in a water bath with the lids and rings on.
For quart jars
pack the salted cabbage tightly in the jars until the liquid covers leaving about 1 inch of head space take two popcicle sticks or even better 2 wooden ice cream spoon and criscross over the top inside the jar. Cut out some cheese cloth squares to cover or a kithch towel cut up and cover and put a ring on to hold. Place in a plastic wash pan or in a large galss baking dish as these will start to overflow.
Look at daily and if you see some scum do as for the crock. These will be ready in about 3 to 4 weeks. Then you can process as above also.
Try some fresh and cooked it is great. Once you make this you will never buy canned or the fresh from the store again.
Recipe to use
For quart jars
