Carocelle Dishwasher
That would work great on out hot water at work. Not only do we have very hot water, the preasure is also high.
This is amazing
I have an early 1940s "Cameron" dishwasher.
This is a metal cannister that sits on your sink, with a brass drain valve. Inside is a water pressure driven rack. You place your dishes in it, and connect a hose to it from your sink. You put a little soap in the bottom, put on the glass lid, and turn on the water.
When the bubbles start to overflow to the outside container, you are supposed to open the drain (over your sink) and then turn the water on again to flush and respray the dishes.
It did work sort of. I am not sure how doing this really saved much time over just handwashing your dishes, therefore, not sure of the value.
I can go out to the back house and take pictures if anyone is interested. The hoses and such I had to buy to clamp onto my faucet were more than I paid for the unit. I also have the "manual" for it!
Whirl-o-way was another brand of these contraptions back in the 60's and 70's, they were rectangular shaped not round. I believe CR tested them once and weren't too impressed stating the need for a lot of hot water continually running to keep them running. They also made a Whirl-o-way water powered potato/veggie peeler as well.
We had one of these when I was growing up for about two years. I made a few small adjustments and it did a great job. I blocked one of the holes at the top of the verticle center spraytube and one of the holes used to make the wash arm rotate. Then it was suppose to use regular handwashing dish soap, I would disolve cascade in warm water and pour that into the soap dispenser. We did have very hot water and high pressure. You needed to let it run for a good 5-10 minutes. We would let the hot water that drained out fill the pots and let them soak until the water cooled enough to hand wash them. We could fit 6 placsettings in it. We junked it when we got the GE Potscrubber in 1976.
As requested
I have misplaced the owners guide, a flimsy affair that is very old and delicate. I know I put it in a flat bag or envelope, I just can't put my hands on it. I will update you all when I find it. For now, here are some pictures.
Main unit:
Here is...
the drain. You rotate this knob to drain water. Luckily it's all brass with no gaskets to wear out. It still seals and opens perfectly.
Pete---
Wierd as this sounds, it is neither big nor small. The lid, which is a strange glass in the middle but steel on the outside affair, is the size of a very large pan, like one of those big Farberware pans.
There's a big Kenmore microwave behind it, kind of out of sight, but you can see the comparable depth compared to the unit.
You would have to do more than one load to do a meal clean up for say, four people. I just put a few dishes in and a few cups.
To be honest, I was hoping for an expectedly cool water turbine jet sound, but it really just sounds like water spritzing on the inside of a steel bucket! But there is some whirling noise of the central unit.
My wife actually got this, and when I received it, I was not sure if I liked it, tolerated it, and it kind of creeped me out (some older stuff just does that to me. I could never have a wringer washer, can't explain it).
I was thinking if there is interest, and the site owner would like to see it, I could make a video of the thing. It certaintly is oddball.
Maybe a combo video of my American Kitchens Roto Rack dishwasher and this unit.
Kevin,
Interesting! Wringer washers kind of creep me out, too... But I have to admit, the metal/glass vintage Cameron is kind of cute.
Toggle,
I guess the Carocelle could fill that empty space in your zeitgeist left by the dearly departed Paki-spinner. But it surely doen't look like it's worth $40 (asking price on eBay), let alone the $99.99 the mfg wants for one. It's all plastic; probably costs about $5 to make. I guess that's part of the attraction. At least it won't go berserk and try to fling rotating lids at you.
Kevin, that weird glass might be pyrex to withstand the heat of the hot water.
Sudsmaster, maybe what's got you creeped out about wringer washers is that there are ghosts hanging around them?:-)
Re. $99 for those plastic ones new: For another $51 you can get a Danby that's a little bigger than a microwave, will hold dishes from a meal for four, with a stainless steel interior, 160-degree (Fahrenheit) sanitize cycle, and a window so you can watch what's going on.
Soemwhere over the rainbow...
I think that DW is perfect to isolate tableware from someone who has a cold or other infectious illness. Great for the office too where strangers share *beakers* (it's BOUQUET, dear).
A little bleach and voila!
and before anyone says *GROSS*, restaurants do that ALL the time.
My germ-freak mom got a Lady Kenmore TOL real DW just for the *sani-wash* cycle with a 155*F(60*C +/-) boosted-temp rinse. My father got it for her because Consumer Reports magazine said it saves hot water as compared to hand-washing.
Each of the trhee children was assigned a color of Tupperware plastic tumbler (choices were red, yellow, green, blue). Heaven help you if you used the wrong color. Cross-contamination was a no-no!
The colors were primary colors then (dark, intense and they did not include a "sippy-cup" TAPA (cover)
http://order.tupperware.com/pls/htp....show_item_detail?fv_item_number=P10048897000
DG,
Not a chance that I saw any wringer ghosts. But I do remember when I was about six years old, being taken to someone's home, and there in the kitchen was a big wringer washer. I couldn't believe it was really a washer. Up to then the only washer I had known was a 40's Bendix. Maybe the hostess was the scary part - I remember a very large and bossy woman who had a superior air about her creepy washer. In any case, that's my first memory of a wringer and it still creeps me out just a tiny bit.
A countertop Danby sounds far more sensible (and cost effective) than a cheezy plastic water waster like the Carocelle.
Toggle,
Your mom was smart to get a hot rinse machine. But colds are not spread by dishes, not even by kisses (at least not the mouth to mouth variety). They are spread by hand, such as nose to hand to doorknob to hand to nose or eye. The mouth is not a hospitable environment for cold viruses. There are diseases that I suppose could be spread by dishes, but after a run through even handwashing any chance of cross contamination would be virtually nil.
Agreed.
Machine dishwashing kills 100 X more germs (literally, not an exageration (sp?)) than hand dishwashing.
I read that same facts you jsut mentioned.
Toucing one's eyes by the bridge of the nose is were most microbial contaminants enter the human body and leads to colds.
