Christmas in July: Surprise G.E. Filter Flo!
thatwasherguy
Aug 13, 2019
286
Kentucky
Hey everyone! Hope you’re all well. Back in December, I was contacted by a family friend who was getting rid of his 1989 G.E. Filter Flo, and wanted to know if I wanted it. Of course, I replied with the only answer that there is to that question, yes. Fast forward to today, when I got the call to come and take it away. I’m told that it has a small leak, and that it has a strange metallic noise. He told me that he mostly ran it on gentle speed, so I’m thinking it’s the clutch that’s causing the sound. I’ll have to run a test wash and look for the leak. Other than that, I’m told that it’s fully functional. It’s in very good condition for its age, minimal rust, very few noticeable scratches, and VERY clean underneath. The tub seal and inlet valve, along with multiple other parts are also almost new, as they were replaced by the previous owner. Having said that, this one is getting saved for the collection.
Thatwasherguy.
    3.1 MB
I’ve tested the machine, and found that the clutch is, in fact, what is grinding, and the source of the leak is the pump. It also has a jury rigged lid switch, so I’ll probably fix that too, and add in a bypass switch like my 1978 Maytag has. I’m wondering if the motor shaft has been damaged at all by the failing clutch. I suppose we’ll find out when I take it apart. Either way, I’m not super optimistic about the condition of the clutch itself. It was run for at least 6 months in its current state, so I’m betting that it’s got grooves in it, and that changing the pads won’t fix anything. On the bright side, however, the rubber parts are all still nice and supple, and the transmission still sounds nice and smooth. With a little bit of POR-15, what little rust it has should be killed indefinitely. Definitely a keeper.
Thatwasherguy.
