CL - Vintage truckload
Exactly, Malcom
I was hoping the Kenmore would be a big-burner gas model, would like to play with one of those sometime - a dryer with moxie!
The Hotpoint washer may also be interesting depending on condition, it may be a large capacity (four water levels - hard to tell from picture) so I could use it to convert into a more vintage (looking) GE filter-flow...
A friend had that gold HP stove in his house in Arlington built in the erly 70s. If you put a high BTU burner from a perforated back cylinder dryer, especially from the Soft Heat models, in a solid bulkhead dryer, you can get some really fast drying out of it. If your current dryer has a heat selector switch, it will no longer have any say about the drying temperature because the only thing that controls the burner is the capilary bulb attached to it. It's a real "hold onto your ass" dryer after that.
Ha
I love the American Flag sticker on the dryer console.
Also, the lid handle on the washing machine looks a little odd for this model.
Malcolm
Whirlpool LDA5800 handle
That must be a replacement handle for a metal one that broke off, which would indicate the washer was built slightly before the dryer next to it. While the dryer has the plastic handle, I am pretty certain the washer did not, otherwise you would see a hole in the lid where it should have been. 1976/77, when these models were being sold, was when Whirlpool was changing over to the plastic handles. Nice set.
