Hoovermatic from October 1973. A bit on the pricy side considering the age and that the heater does not work, amongst us all there should be no problem scaring up a heater
I wrote to the seller re the heater and said about the heater not working if no water in the tub as it has a safety switch they are going to retry it and amend the ad if it works.
This looks similar to the last although this actually appears to be a 920 dishwasher, it certainly has more cycle selections. Lo0oks like a project but this must have been TOL for its time
"I will give it a clean before its collected" - for £50 (never mind £150) and not fully functional I should bloody hope so! The door with the oven door was for a viewing panel
This was the first electric cooker I came across, an Aunt had the one without the options this one has. I have many fond memories of cooking on it with her when I was a child. As standard it would have had a 6" solid boiling plate at the front with the control (second left) only graduated Low Med High. The viewing door was another option against the solid door and inner glass door.
Ian
