Clog on a KitchenAid KDS-16
Leak On Both Sides Of The Machine
Did you run the machine w/o the bottom rack in it? If you did, that could explain the two leaks on both sides of the machine. There are two tabs at both front corners of the lower rack that stick out at a 45 degree angle from the rack. These seem to have something to do with a KA leaking at the corners. I did that myself once, but when I put the rack back in, the leaking stopped.
Suds in DW
I noticed there are other suggestions on how to get rid of over sudsing in machines other than the one I have always used and thats sprinkling table salt on the foam wait for it to dissolve and then retry a pump out.! I will try the oil one when I have to that is a new one...!
Answer! Clogged Hose or Drain Problems Fix - Replace Hose
If your drain hose is clogged or dishwasher won't empty the water, or stops mid-cycle or leaks. You most likely have to replace the drain hose. This video will show you how to do it, and its very quick and easy to do. I knew nothing about these machines, and this videos was created so individuals can save money and make the repair themselves confidently. It will cost $10-15 and take about 20 Minutes.
