Clorox Ultimate Care
Does anyone know about this product or have any experience?
I picked it up today at my local grocery store(The Big Y which is across the street from KMart....I tell people I shop at the Big KY...ducks and runs).
Anyways, feedback welcome.
I'm curious about it as well.
Is this a replacement for Clorox II, which to me, has never been more than somewhat effective?
If I remember, Steve-SactoTeddy mentioned this a few weeks ago.
I don't use regular Clorox a great deal in laundry, though I do use it as a household cleaner/disinfectant.
Lawrence/Maytagbear
Household cleaner.
Just remember Clorox or other brands of bleach do not degrease or hold soil in suspension. Its ability to actually clean is limited IMHO.
It is great for disinfecting and deodorizing and de-molding and de-mildewing.
Just a thought.
And a correct thought it is...
Toggle is correct, bleach has little "cleaning" ability but is a great disinfectant, mold/mildew remover and of course, it's laundry uses for whitening and brightening.
The ultimate care sounds like an Oxygen bleach, probably with some added surfacants and enzymes to make rinsing even more difficult in water-stingy machines.
Bleach Cleaning Ability
I still think Clorox Chlorine bleach does clean. IMHO
I have washed dirty white dish towels in just hot water and detergent, and they still had stains left behind.
I wash them in detergent and bleach, and they came out spotless.
Does this make sense? Bleach does get out the stains. So... How can bleach not be considered to have cleaning abilities?
Maybe it is just me, (an avid bleach user who likes his whites white), but if someone can explain, I would appreciate it.
Thanks,
Ray
Bleach is a bleaching agent which can improve the stain removing of good laundry detergent, but as I read somewhere, bleaching is no substitute for proper laundering methods. While caustic, it is not a surfactant and is not a cleaner by itself. Greasy discoloration will not be removed with bleach. Either STPP with the detergent or that gel (Shout or Spray & Wash?) applied as a pre treater is best for grease. My favorite discovery about bleach is that when mixed half and half with water and applied to the tile and grout above the tub or in the shower and allowed to dry will not only result in snow white grout, but after the second or third time that this is done, no more dark stuff grows in the grout. Of course, some people do not like the swimming pool smell of the chlorine, but it brings happy memories to me and smells really clean so I like it.
Bleach
Hi Tome,
I agree with you in that bleach needs to be used with a good detergent. However, it has always been stated that you should let the clothes wash first in the detergent for at least 5 minutes, letting the detergent do the work first, then add the bleach. My LG's bleach dispenser does this. It is said that if you add bleach at the beginning of the wash with the detergent, the bleach actually slows down the detergents cleaning ability. I also happen to like to tell tale signs of bleach. It is just such a clean smell. I like to clean my bathrooms with Clorox Cleanup.
I just think that some people are afraid to use bleach. There tidy whities must not be that white. (LOL). If used properly it does work.
Thanks for your advice and opinions.
Much appreciated.
Ray
Cleaning with bleach
I use Clorox Clean-up for all of my cleaning. It is bleach with a cleaner mixed in. It works really well, and leaves a very nice, clean scent.
Tim
Except for enzyme detergents, bleach would not slow down the cleaning. It's the optical brighteners in many detergents that would be canceled out by the bleach if it was added before they had a chance to work. The Maytag metered bleach injection introduced in 58 or 59(?) did not delay the addition of bleach to the wash water. Once the fill was complete and agitation started, the pump pulled the solution of bleach and water out of the reservoir and shot it into the outer tub. This was far better than the cheaper methods of dispensing bleach where it basically goes right into the bottom of the outer tub so that clothes at the bottom of the tub are exposed to a strong bleach solution when the washer starts filling. I think a more even way of adding bleach was pouring it slowly into the filter pan while the GE washer was agitating. Almost instantly the whole basement would have that wonderful fragrance of serious washing as the chlorine rose in the steam from the 160 degree water. The new front loaders that siphon bleach into the fill stream get dilution OK, but if I bleach in the Duet, I don't want it going into the rinse. I dilute the Clorox & add it to the hot wash water after 5 minutes.
Bleach as a cleaner.
When I went to visit in Puerto Rico, it appears to be very fashionable there to use bleach BY ITSELF as a floor cleaner [Terrazzo floors]. (Cheap, available and kills the mold and mildew).
Does great with mold and mildew but the greases and oils do not get lifted. They stay on the surfaces (floors) because the water does not have a surfactants needed to hold the greases/fats in suspension. STICKY MESS.
What soap and detergent does, is act as a temporary emulsifier. [They way an egg holds together oil and vinegar to make mayonnaise]. Back to soaps: one end of the molecoule is hydro-philic (likes water) the other end is lipo-philic (likes fat/grease). Detergent therefore allows water to hold fat/grese/dirt in suspension (emulsified, if you will) and take it away.
Ray: Would you use bleach ALONE inyoru wash? Probably not, because the DIRT would be bleached white, but would not be removed from the clothes. Bleach is an OPTICAL brightenr. It takes invisible ultra-violet light and lowers its vibration to make it visible light.
In Spanish, bleach is called *BLANCEADOR* to make things BLANCO (blank) or WHITE. It is a whitener and disinfectant. Period. Full-stop.
Is bleach earth friendly?
I work with a guy who for years worked in a chlorine manufacturing facililty. He claims that LCB, like Clorox or the various store brands, is made safely and is safe for the environment. All of the environmental literture, however, seems strongly against both the production and the use of LCB. So...what's deal?
LCB breaks down rather quickly after being diluted in wash water. I read somewhere that the half life of dispensed LCB is 6 minutes. LCB is sodium hypochlorite, so when broken down is similar to salt water.
