"I remember the washer only version of the Colston had a very odd final spin cycle, where it would continuously speed up, slow down, speed up etc. Never seen anything like it before or since. "
The reason for this is the clever motor arrangement. These use a particular type induction motor, a characteristic of which was a very slow spin. There just isn't a great enough difference between the slow speed (for wash) and the fast speed (for spin). A few Italian machines of this era used an expanding pulley to speed up the spin speed - on wash the two halves of the pulley would be wider spaced, so the belt would run on the inner edge of the pulley, a smaller diameter and thus slower speed. When the motor hit spin speed, the pulley would expand due to centrifugal weights behind the pulley forcing the two halves closer together, thus squeezing the belt to the outer edge of the pulley... larger diameter pulley gives faster belt speed. As the pulley expands, the motor rises up on the belt and moves closer to the drum.
Indesit used a clever extra feature - a microswitch is fitted between the motor and drum. When the slower spin speed is selected, the motor spins up to speed till the motor rises up and compresses the switch, then the power to the motor is cut, the motor slows, the pulley opens up and the motor drops back down...till the switch is released, then the motor starts up again, expanding the pulley, lifting the motor, compressing the switch and turning the motor off again, to repeat the cycle.
If you select the fast spin speed - a blazing 800 rpm - then that microswitch is bypassed, so the motor runs at full speed for the entire spin time.
I really like these machines, I have owned a couple some years ago. Mine were South African orphan imports, they had four option buttons and a black fascia instead of chrome.
I have a spare motor for these in my shed, but it is on the wrong side of the planet to be any use to you - postage would be prohibitive.
