Copy Cat Picture Window Dishwasher
I had to cut the notch so the glass would make a good seal due to a contour in the door, that's also why it off-center. I can fix all that with the trim
Its a piece of aluminum 1 1/2" angle and a 1" aluminum flat stock. This is what it looks like from the inside
Then I took it all back apart and ran a bead of ultra blue around the windows and tightened up all the bolts.
