I have been having problems with my Bosch Exxcel 8 recently, mainly the machine going into pause mode and flashing NO, even when nobody is near the controls.
Today I was doing a load and noticed a horrible electrical burning smell in the kitchen which seemed
to be coming from the washer. After closer inspection I traced the smell to the cupboard next to the machine that houses the socket that the washer is plugged in to. I was horrified to see scorch marks on the plug top and after isolating the socket and removing the plug, the source of the smell was obvious.
This must have been happening for a while as I remembered noticing a smell when I opened the cupboard, but thought it was a pan that my partner put away without being properly cleaned. I meant to clean the cupboard out, but forgot until the smell this morning reminded me. When we moved into the (new build) house, I had to drill a hole in the cupboard to pass the cable through and as I didn't want cut off the original plug, I used an extension lead with a 3kw rating. Also the socket had been positioned too close to the base of the cupboard, which meant that the cable was bent where it enters the plug.
I will be replacing the complete socket in a higher position and making a hole large enough for the original plug to pass through, eliminating the need for an extension lead. I hope these changes will prevent anything like this happening again, but do you think it is possible that the scorching on the plug and socket would cause the electronics in the washer to malfunction?
The socket for the washer has a seperate switch that isolates it and we always turn it off after we have used the machine which is a good thing because it could have started a fire. I don't care about the kitchen or house being damaged by fire, but it's the dogs that I am concerned about. I am so glad that I was downstairs while the washer was going or things could have turned out far worse.
