Coverting a 220V dryer to 110V
No actual details; WAY too much risky jackleg ideas
We can all different on our experiences. Here I am a registered EE in California, thus I do not sign off on a conversion of some device with zero details, it is basically to darn risky.
My experience has been that most all older dryers were simple designs and were designed when I grew up to run on 120 or 240 and the coil in 240 mode went across the 240 volts, and was across the 120 in the 120 volt mode or low heat mode.
The reason most all did this is the coil is simple; it has only two ends and is not tapped. To run on low one just used a switch.
Older dryers did not use an expensive triac to place 120 across the coil, they just used a simple dumb switch.
Basically to say to another that one can convert an unknown USA 240 volt dryer to 120 without knowing the model, schematic with an adapter cord is risky, ie casino betting, loony toons. At best it is a roll the dice and smoke test. ie you plug it in and look for smoke.
The proper way to design to convert running a 240 volt device on 120 volts is to actually provide some ACTUAL details, which is not done here at all.
Using an adapter cord on a totally unknown 240 volt dryer makes you a hero if it works, or wanted man if there is a fire or fault and one has insurance losses or somebody gets killed. Thus with an electrical fire report ones reports eludes to jackleg, or guessing more than solid real engineering.
It seems the trust of this thread is pure generalities; ie never mention the make or model and hope with dumb luck that the conversion works.
Even if it works for chap#2 today , another chap #34 can find this thread in a year and ruin his dryer, get electrocuted, or cause a fire and one might have a legal attack.
****Thus why not rise up and reduce the uncertain variables and provide an actual model number, a schematic?
ie an actual basis of the actual dryer to be converted?
This is the reason engineering is regulated in dealing with public matters, and why many cities have electrical codes with rules. The bulk of home electrical fires are caused assuming.
What is the FEAR in actually providing the model # or schematic?
Jamie,
If you are attempting to wire that Kenmore Electronic dryer you got from me to run on 120V, you might want to look in the manual. I know it says something about a special way to do it, but when I looked in that section, it gave no diagram of how to do it. I'd say if you afraid that you would ruin the computer board, (which costs a few hundred dollars to replace) by doing this, just wait until you have the proper electrical supply to run the dryer. If you are good with reading schematics, you could attempt to trace the circuitry of the electronic controls, and see where the two hot electrical lines go, and what they do in certain places in the circuitry.
AT THIS POINT, IF YOU DO NOT KNOW WHAT YOU ARE DOING, JUST LET THE MACHINE BE. Wait until you have the proper Electrical suppply before using this machine. (Just sayin)
Not the Kenmore!
It was never my intent to wire up the Electronic Kenmore dryer for 120v! I was thinking more along the lines of getting a new 27in Whirlpool dryer and running it off of 120V.
Jamie, why not simply consider a Tag portadryer, or whirlpool portable. The little whirlys are on CL often, signed plug & play. alr2903
CONVERTING A 240 DRYER TO RUN ON 120 VOLTS
All US 240 volt dryers that are made in both gas and electric versions can be easily and safely run on 120 volts either for testing- demonstration purposes or even drying clothes. Anyone doing this must have enough knowledge and sense to make sure that electrical connections are made properly, that the machine is grounded properly and that it operate properly when it is connected to power. If anyone is unsure of doing this they shouldn't do it. All dryers have a wring diagram attached to them and one only need to look at it to see if the conversion is possible and how to do it.
