bobbyderegis
Hi All:
The new A712 is mint, except for the way the motor starts at the beginning of the first agitation. If the speed selector is set on regular (fast), the motor makes this strange sound for about two seconds. If the speed selector is set on slow, the washer makes the same sound for about two seconds, but runs at fast speed for about another two seconds, then kicks over to slow. This only happens the first time the washer is used after a day or so. If you wash a second or third load right after, it does not happen again. The sound is hard to describe, but if the washer was under water and running, it might sound like this! Anyway, I took the motor cover off, unscrewed the motor switch, cleaned up some lint and grease, put it all together, and the problem seemed to be solved. A day later, I washed again, and the problem was back. Last night I pulled the switch off again, played with the start winding kick out arm, ran a cycle and lo and behold, the machine ran fine. I will see if after a couple days the problem returns. What the hell could be wrong? The motor switch has been discontinued, so I can't easily replace it. Has anyone had this situation before?
Bobby in Boston
Bobby in Boston
