Creda Reversair tumble dryer belt needed.
slpj
Active member
Dec 28, 2016
39
Kent
Hi all.
I still have a Creda reversair tumble dryer, bought new in the early 1980's.
It still works like new; except, the ORIGINAL drive belt, finally snapped just yesterday.
Can anyone tell me where I may get a replacement?
Apart from it working perfectly well other than the belt, I'd REALLY hate to replace it, or worse still see it end up a scrap. Especially as to look at it, it still looks like new as well as still works like new ( albeit it would with a drive belt).
The snapped belt measures 1888mm, and is about 8mm wide. It has three v shaped ridges.
Can someone help me please?
P.S.
The model number on the rear panel looks like
"27405". Possibly 37405, as the lable is a bit crinkled , but I think it's much more like 27405.
Thanks.
We have used HADCO for parts for my Creda washing machine. Phone number 1-800-241-9152
I also have a phone number for Creda 1-800-800-2733, I do not know if we have ever used them.
I have no idea if HADCO is still in business or if your part is available. I believe that better auto supply stores have a belt measuring device where you can take a belt in and they can measure it to supply you with a replacement belt. Best of luck.
Hi,
Thanks both.
No, unforunately those won't work, too long and wrong cross section..
Also, I'm uk based btw, so need a uk supply I think.
I'm wondering if I could get the correct length, even if it is too wide, perhaps I could split/cut the width to size. What I really need is some new old stock.
Hi there.
Glad to see that your 37405 has still been doing its job, though sadly now needs a bit of a repair.
Your model is definitely 37405 and I think I have found a suitable belt on ebay.
Hope it helps.
Paul
ps if you don't have an ebay account - let me know.
https://www.ebay.co.uk/itm/164935229888
Hi Paul,
Thank you very much. You're dead right. Model 37405. I took a picture and blew it up a bit.
And thanks too for locating the belt for me, and at such a very good price.
Belt bought. Hopefully have it running again by next weekend.
A question.
What is the easiest way to fit the belt? As it was snapped, it just fell out of the bottom with the inspection cover removed.
It looks like I need to remove the front of the dryer, to feed the belt over the drum. Is that correct?
I don't suppose there's a strip down manual (pdf file) for it is there?
Hopefully it will be suitable and do the job - fingers crossed!
Afraid I don't know the in's and out's of belt fitting to vintage Creda's - fairly good on their history, but useless with the practicality of repair. Hopefully someone else will be able to assist with that side of things.
Annoyingly, as far as I know, no Creda servicing info has ever surfaced sadly.
I'll nudge a couple of people and see if they can help.
Paul
p.s your Creda 10700 says hello :-)
A Creda 10800 surfaced near James, which he was able to save and he then passed the 10700 on to me.
A replacement lid was provided for it, so it really looks the part now.
Once we move into spring and summer, it will undergo testing to see what winter has done to it (along with all the other machines) .....
Brilliant.
My mother who it was bought new for, would be amazed and chuffed to see her old Creda 1000 looking so good, and so well cared for. 😊😊
The tumble dryer, used to sit on (stacked) the Creda 1000 in our kitchen in Streatham. After she died, I moved and took both with me, and stacked them in St Leonards east-sussex. Then I brought them to Kent, and only when the washing machine was beyond my abilities to get the parts and repair, did I let it go. I was very happy yhst someone wanted it renovate.
But I couldn't let the dryer go, because not only does it work so well, it just didn't feel right to sell it. And now with a new belt, it'll go on for a lot longer still.
It was either that, or buy a new dryer; probably a Meile, since that's what I replaced the Creda 1000 washing machine with.
fitting the belt.
Hi,
I've distant memories of fitting these belts, and I'm sure your on the right lines with removing the front panel, slipping the belt over the drum, now I can't remember if you could then reassemble with the belt loose, then go in the lower panel and slip it over the motor and tensioner pullies or whether you go with the belt fully on motor and drum and during re assembly you had to work with the tension of the belt both on the drum and motor. Anyway definitely worth the effort and far easier than replacing the belt on a modern condenser dryer.
I seem to remember one frustration was lining up the exhaust tube that fits between the front filter chamber and the back panel.
Hopefully that may give you some confidence to get this lovely dryer working again.
All the best
Mathew
Service info
I was lucky enough to pick up some service information for Creda machines from around the time Hotpoint had taken them over. The information covers Creda designed machines - the dryer service info shows as Hotpoint Creda whereas the washing machine I’ve attached shows just Creda but all have the Creda address on them.
It doesn’t have your model number but I’ve attached the later model details as quite often these updates were more about cosmetic changes rather than engineering redesign so it might help.
As Mathew has pointed out, it looks like removing the front is the way to do it. Good luck and keep us posted
Steve
Hi Mathew and Steve.
Thank you both very much for that information.
It seems I managed to guess along the right lines then lol.
Luckily my dryer is rear venting, so it looks like it will be less complicated to get the front off. But those exploded pictures, and list of instructions from the service manual, even though not identical to mine, make it much much easier to undrrstand what to do.
As soon as the new belt arrives, I get on and do it, and take plenty of pictures as I go; just in case they might be useful for someone else in future.
Thanks again.
That's a great pamphlet Paul. I thik I remember it from when we chose/bought our 1000 and 37405 tumble dryer.
How does the sensamatic dryer work? Does it sense moisture and switch off when the the stuff is dry, rather than by the rotary timer switch?
New belt fitted. Quite an easy job which was a pleasant surprise.
Started at 10am.
Finished at 11:45am.(Same day😄).
Took top off.
Took base front trim off.
Took timer knob off.
Took timer knob trim off.
Took timer switch and plate out.
Took heat selector switch out.
Removed rear air duct screws.
Removed 4 front air duct srews from front cover.
Removed remaining front cover screws.
Removed front cover.
Removed air duct.
Fitted new belt.
Reassembled and tested.
