sesteve
I’m not that familiar with these but the item you have highlighted is the earthing strap for the drum. According to the service gumpf for the larger sized dryers, the thermostat, cut out and thermal fuse are all part of the heater assembly and it looks similar to yours. If your replacement element came with those bits attached then a direct swap should sort it out. Otherwise I would check the thermal fuse and replace
Hope this helps
Hope this helps
