Eddie
Of the two, the Maytag can eek out a head a bit, even though they are both essentially the same machine with slightly different features. From what I've understood from a couple of people here and on other laundry forumes, Maytag is what KitchenAid laundry products used to be and probably would have been if Maytag hadn't had it's brand name thrown in the mix. Some of the components are supposedly beefed up over the WP cousin--door hinges, sturdier drive belt, ... Neitehr one has a supplemental heater. the Maytag MAY, but I question that. The Maytag has a PowerWash cycle that's very long and does use hot water, but hot water isn't going to stay hot for an hour or 1.5 hour wash phase. It has a "stain tret" option which changes any preset wash temp to warm to deal with protein stains. It adds time, different tumbling patterns. Who nkows, maybe this is how laundry will be done if, what Malcolm has been told by Speed Queen, all washers with supplemental heaters will be going away in 2-3 years for energy Star purposes and and detergents designed to work with cooler temps. Of the two, I'd opt. for the Maytag if I had to choose. I can tell you I definitely lke it's beheamouth big brother Mr. Steam engine and will rpobably spring for that when my Fridgemore gives up the ghost. It's a different approach to doing laundry, but I still personally am of the opinion front loaders wash much better than top loaders.
