58limited
Has anyone ever seen one of these? I thought it was pretty neat so I bought it. Probably made in the early 1930s by the Cube Steak Machine Co. It is 14 inches wide, 21 inches long, and weighs 60 lbs.
You place a round steak on a platen under the slotted blade guide and pull the handle to run the blades across the meat. The platen turns 1/4 turn with each pass. Unfortunately, it is missing the platen and the turning mechanism. I can easily make a platen but will have to turn it manually, not a problem since I am not a commercial butcher shop and therefore won't use this a lot.
