vacfanatic
- Joined
- May 17, 2009
- Messages
- 380
Call me cheap but I don't think $320 a piece for Miele Pedestals here in the USA are worth it.  I built my own pedestal this weekend for about $200 in materials, and about a day and a half of labor.  I built it out of 2x6's and 5/8" plywood.  Every mating surface between boards and framing were given a generous squeeze of heavy duty liquid nails, and I used probably over 100 screws.  I filled the cavity with blown in insulation so it would not have that hollow sound.  The end product weighs about 200 pounds and you could literally park a semi on it.  I've just got to finish sanding the nail holes and then paint.
 Don't worry, I already planned to strap the back legs of the washer to the back of the pedestal in the unlikely event it ever started to walk.  I will probably use some of the same stuff you use to strap water heaters to the wall in earthquake prone cities.  I'll just have to fold it in half so I can wrap it around the back feet and then bolt it to the back of the pedestal.  If it ever did start to "walk", it would just rub against the wall.  No chance it could fall off.
