Danby Opinions?
Thanks for the photos Jeff. The perm press cycle has the kind of water level I am looking for. Hopefully these models are still available?
Well, it's pretty obvious. The only problem is that my machine has a simple open and close switch and yours has a single post, double throw switch. I guess I'll have to figure out if my machine really has a switch like yours and is used in a more simple fashion so I can rewire it or if I'm going to have to find (maybe order) a more complicated switch. We'll have to see how it goes.
Steve
Mistervain, I’m not sure if these models are still available. It sounds like the dealer may have sold me an old machine, but that’s okay because I like this one better. I called the dealer today and they are out of business. They only do service now. The availability probably depends on your area. Put your zip code in the dealer locater page at the Danby website, or check with your local Home Depot. The link is the Danby site.
Good luck, Steve. I thought about adjusting the screws on the water level control, but I’ve never seen one like that before. Let me know what you end up doing.
Jeff
http://www.danby.com/en/locate.asp
Water level switch was indeed the "first" Danby washer to sell in the US. Subsequent models had the water plus button switched out. Proof of this is that the new models still used (or still use for all one knows)the same owners manual as the previous one which list features like the extra water buttton which is no longer there.
L.
About Video for Danby
Hello I'm deaf.
Can you make the video (movie) about the Danby's wash action (activity), rinse and spin? (run wash tumble of 2 directions drive)....is that OK? Thanks! ;-)
- Peter (kenmorepeter5)
Jeff I am definitely going to check out some of the dealers in my area. I appreciate the tip and everyone's feedback. This topic has taken on a life of its own!
I'm very interested to find out what happens from playing with the wiring on the water level switches....
It seems to work...
I made the modification. From Jeff's clear descriptions, I have the same water level that he does when he pushes the water plus button. I couldn't use the gentle wash button because it is a simpler switch than what Jeff has. So I chose to buy a switch and mount it on the back of the machine. I found a switch that fit the left shipping rod hole. The way that I've wired it, up gives me more water and down gives me less. Seems logical. It would also be possible to simply wire it to always have the extra water on the cotton cycles and not bother with a switch. That would be a simple wiring change. Of course, you could drill a hole in the front of the machine and make the switch more accessible, if you want. I'm still in the middle of the first wash. I need to try it both ways some more to make sure that I don't smoke something. But I think I have it right. If you think that watching your Danby from the front with a flashlight is fun, you should try watching it with the top off. It's quite cute inside. :-)
Steve
That’s great, Steve! I know you’re happy. The switch is good to have when you wash towels, because on the higher water level; towels seem to have too many suds due to the showering effect the higher water level causes. Can you still use the gentle wash button?
Jeff
Yes, I didn't disturb the wiring of the gentle wash button. I'm not sure when I would ever use it, though. I see what you mean about the towels. My test load is a set of towels. This is a small load and I'm using an eighth cup (two tablespoons) of Ariel Baja Espuma with fairly hard water (but magnetized, which is another story). I suspect that it wouldn't suds as much with a full load to use up the detergent. Baja Espuma is a low suds detergent. I'll have to get more experience with it.
Steve
STEVE I'm not electronics-knowledgeable at all but if you rigged it like that couldn't anyone? Meaning would all the Danbys have those same switches you played with.
Actually, I didn't do anything with the Danby's switches. What I did was to add a switch so I could switch between two water level sensors like Jeff can. All Danbys seem to have the same water level pressure switches, unless they change that at some point. All that is needed is to add a switch to take advantage of them. At least that is my current experience. The nice thing is that Danbys don't have an embedded computer in the traditional sense like the Askos and Mieles. If they did, it would be much harder to modify them. Danbys use a reasonably sophisticated timer to get everything done. You can think of it as a mechanical computer. There's a logic board, but I believe it handles the low level logic to do things like handle the back and forth motion of the drum. This is just a guess. This was all facilitated by the fact that Jeff has a wiring diagram of the old machine. The old and new diagrams are identical except for the change that they made to get rid of the water plus button and make it a gentle wash button.
Steve
Jeff,
I have a question about your experience with your machine. The manual for your machine (from the Danby web site) says that the water plus button only works for the A and B cycles. I doesn't mention the C or D cycles, but does say that you can't change the water level for the delicate and woolens cycle. It looks to me that my switch changes the water level for the C and D cycles as well. I haven't tried the permanent press cycles. Have you determined which cycles work with the water plus button?
Steve
Steve,
The water plus button works anywhere on the dial during the wash portion of the cotton cycle between “B” and the cool down. I’ve tested it by pushing the button anywhere in that range and it will fill until the water plus level is reached. “A” (pre-wash) is always the same water level as the cotton cycle w/ the water plus button pushed and so are the rinses in the cotton cycle. The perm press cycle has a slightly higher water level. “K” which is the rinse in the perm press cycle before the only intermediate spin, has the highest water level of all which happens to be the same as the Wool cycle’s water level.
Jeff
Thanks for the info Jeff....I emailed Danby and they said I needed the hookups in my condo to use it....but if what u r saying is true how could I hook it up since I'd have to use the tub or kitchen faucet to fill and drain? Sorry for the seemingly dumb questions but I'm just seeing if there's a way I can do this.
Kitchen faucet connection is easy. You'll need a "quick Connect" faucet adaptor set(found in any hardware store), and perhaps a "Y" connector if the washer needs both hot and cold water lines connected. If the unit does not need both lines connected, cap off the hot water line and connect the one hose to the cold water line. Water temp is selected from the faucet, but the unit will sense wash water temps and "heat" where necessary.
If the washer requires both hot and cold water lines, hook up the quick connect adaptor and use the "y" connector to split the one hose off the faucet to two separate water lines, "hot" and "cold". Again water temp will be decided at the faucet and the washer will "heat" where needed. This means if you choose "hot" wash and the water is warm, the heater will kick in (certian cycles only). If you choose a warm wash and the water is too cool, the same.
These instructions are for kitchen faucets that are single, if you have two separate taps, you just need two quick connect adaptor kits (one for each tap and hose) and complete installation as usual.
Problem with using quick connect adaptors is you are tying up the kitchen sink until laundry is done. You may wish to look into having a plumber install connections under the sink off the existing pipes. This would allow you to do laundry while not tying up the kitchen taps.
Launderess
THANK YOU Launderess! I'm going to look into this....and find me a Danby with the water level options! :)
Jeff whats the exact model number of yours ? I don't want to get the version that doesn't have the water plus button.
quick connect adapters
"Problem with using quick connect adaptors is you are tying up the kitchen sink until laundry is done. You may wish to look into having a plumber install connections under the sink off the existing pipes. This would allow you to do laundry while not tying up the kitchen taps."
Sometimes, though, those quick connect adapters will drip a little while under pressure, and while being disconnected. This wil drip water into your undersink cabinet, so be aware
Someone posted something about this in a "hacking your Danby" topic on THS (might have been you?). Well, *finally* a hackable modern washer! I despair of all the computer-controlled "idiot-proof" stuff that's also "genius-proof" and can't be modified. There is a magazine called "Make" that's geared toward people who like to hack everyday technology; they would probably publish an article on that if you wanted to write one. www.makezine.com
Re. sink hookups:
Check your manual and/or call Danby before trying the sink hookups for the FL; there may be an issue with regard to a need for a certain minimum water pressure.
The way to prevent a sink/faucet hose from dripping where it shouldn't, is simply to have it drop down a bit before it goes back up to exit the sink. Think of a "u" shape, where one end of the "u" is into the faucet, and the other end is curving up before exiting the sink.
The other thing is, I don't know that there are any FLs that are designed to be wheeled around on casters like portables; the spin cycle vibration would tend to make them scoot around on the floor. In fact, if you're using temporary connections, watch out for the scoot factor; you definitely don't want the washer to pull its water connections loose.
Mistervain, the on line manual at the Danby web site (which documents the old machine) is model DWM5500W. My printed manual which is for the new one is model DWM5500W-1. That may be the difference. Good luck finding the old one. If you can't, you can always hack it. :-)
Steve
Thanks designgeek for the info. STEVE I have called around and no luck finding the Danby with the water-plus button. The only thing feature a salesperson mentioned is the extra rinse button. So I'd have to buy it and hack the system but would definitely need some guidance from someone who's done it! Let me know what would be necessary (tools, procedure, etc.)
The Danby does have a hot and cold hook-up, so you will need to split the one hose off the faucet to two separate water lines, "hot" and "cold" on the back of the machine, as Launderess mentioned above with a “Y” connector.
Designgeek brought up another interesting point. The machine should be placed near the sink in a permanent spot and leveled since you will not want to keep moving it.
The model number on mine is DWM5500W as mentioned by StephenRO. The new model has a “-1” after the model number. The easiest way to tell the difference in the models is to look at the buttons on the machine. The 3rd button from the top is either “water plus” or “gentle wash.”
As far as hacking it goes, Steve hacked his and it seemed to be very easy for him. Perhaps he will share with you how he did it. On the other hand, I have a friend that has the Danby w/ the “gentle wash” button and he likes his machine. The “water plus button” is a nice feature, but it’s not necessary for clean clothes.
Good Luck,
Jeff
Modification procedure
Here's how to make the modification to the newer Danby washers to get back
the water plus functionality that the first version had. You need to be
prepared to do quality work. This procedure is not particularly
difficult, but if you aren't confident about it, you should probably find
someone that's used to these things to help. Of course, I take no
responsibility if you smoke your machine. I'm sure this will void the
warranty, as well.
o First, you have to take the top off the washer. It's only held by two
screws in back and easily slides to the rear to be removed. On the under
side of the top is a wiring diagram that might help you figure out what
we're doing.
o Locate the wire to cut. To do that, locate the timer. It's in the left
front of the machine just under the top.
Locate the White-A connector. There are four connectors each with twelve
wire positions on the timer. You can see colored dots on the timer to
identify them, green, red, and black. The one towards the front doesn't
have a dot and that's the white one. Unplug that connector from the
timer. There are two plastic snap levers that hold it on each end.
The wires that go into this connector are labled A1, A2, A3, etc. They
aren't color coded. We are interested in the A1 wires. There are two of
them and they both go into the first position on the connector. We need
to cut one of them. Unfortunately, it's not obvious which one. They are
both labled A1. The one we want goes to the first position on the
connector on the water level pressure switch with the red dot. The last
position on the pressure switch connector doesn't have a wire in it. The
other end is the first postion.
The way that I determined which A1 wire to cut was to pull on both wires
and see which one pulled from the first position on the connector of the
pressure switch with the red dot. You should be able to pull the correct
wire from both directions to make sure you have the right one. The wrong
one won't pull very much because it goes farther in the wiring harness.
You might want to cut the wire tie that holds the wiring harness to the
side of the washer to loosen it up. You'll want to put another one on
when you're done, of course. Once you determine which wire to cut, you're
home free. This is the hardest part of the project.
o Cut the wire. I cut it about two to three inches from the White-A
connector next to the timer. You need enough wire left to use a splice
connector. I used 3M Quick Connects that I picked up at Walmart. These
are designed to tap onto a wire and connect another one to it. But I used
these for all my connections. They are for 18 gauge to 14 gauge wire.
The Danby uses about 18 gauge wire.
o Mount a single post, double throw switch. You might have to look around
a little for this. You want a good quality switch. I think this part of
the wiring runs at 220-240 volts. It's not a lot of amperage, but you
want a good part. A single post, double throw switch has three connectors
and switches the middle one between the two end connectors. One position
connects the middle connector to one end and the other position connects
the middle connector to the other end. I found a toggle switch that fit
into a 7/16 inch hole. This seemed to fit pretty well into the left
shipping rod hole in back. So that's where I mounted it.
o Make the connections. I used 16 gauge stranded wire. I used white
because the rest of the wiring in the Danby is white.
Connect the short side of the cut wire from White-A1 (the one that goes to
the timer connector) to the center connector on the switch.
Connect the other side of the cut wire to the upper connector on the
switch. This will cause normal water level when the switch is in the down
position.
Connect a tap (without cutting the wire) from the White-A2 wire (just next
to the White-A1 wire that we cut on the white timer connector) to the
lower connector on the switch. These 3M Quick Connects are made for this.
They work quite well. This will cause the higher water level when the
switch is in the up position.
o Install wire ties and clean up.
That's it. Water plus is up, normal is down. If you didn't want to put
in the switch, you could just connect the short wire from White-A1 to a
tap on White-A2 and you would have water plus all the time. But I put in
the switch. Good luck.
