New to the club and thought I'd jump in !
I recently purchased this machine from Target. Arrived with shipping damage as Macboy91s pointed out. (Also arrived earlier then stated, 3 days and not 10, luckily I was home as it was also left on the front door step) Thankfully the unit is very light and I was able to get it in and up the steps without any problems.
During my test spin I noticed that the spinner was not up to speed, so I took off the back panel and found the safety break needed to be adjusted. Not a big deal as there is an adjustment plate on the cable.
Mine has a belt drive on the wash side and a direct drive spinner, with the separate Pump in the center. You can move the discharge hose to either side of the unit. It has opening on either side of the cabinet and hose from pump is in the center of the machine.
Capacity is bigger than I thought it would be which works out great as i use it to prewash, soak, and or dye material before running it through my front loader.
So far I am really glad I got it. It's quiet, has a strong wash action and spins clothes quite dry. I am enjoying the HandsOn feel of laundry once again. Just wish I had more space so i could start a collection of washers.
Good luck with your new machine Wetguymd. It will be interesting to hear about it when you get it.
