DD washer has trouble spinning
Marky_Mark
Aug 3, 2014
700
Living in Palm Springs and Madrid. From Liverpool.
Hi guys
I recently got this Kenmore and a problem has occurred today, as seen/heard in my video. About half the time when starting to spin, it can't pick up speed and it keeps clicking. Every time it did this, I tried stopping it and immediately restarting it and it was then able to spin no problem. Also, the neutral drain period sometimes just goes into spin, which I'm mentioning in case that could be related in any way.
Thoughts and advice very much appreciated, thank you!
View attachment IMG_2397.MOV
Hi Mark, take the agitator out and see if the ears on the top of the spin tube are properly engaging in the aluminum basket drive block that could be stripped out and slipping if it’s not that it could be a clutch or transmission problem, basically have to pull the transmission check the clutch for some sort of Mechanical failure if that’s not it time for another transmission.
John L
