DE806 Brush and slip ring continuity
cjw1234
Jan 24, 2022
0
Illinois
Hi All, I have a mustard yellow matching HA806 washer and DE806 dryer. I’ve been using it for several years without issue but just last week the dryer started only running for about 10 minutes before shutting off. I pulled it apart and found the slip ring and brush isn’t making a connection. Everything is very clean and all other connections on both sides check out. But the brush will not make a circuit through the slip ring. To me the carbon brush looks fine and checking continuity through each part of the brush setup is good. If anyone has some advice I would certainly appreciate it. Thank you!
