It's been awhile, but Elginkid and I finally got our 1975 DE806 put back together and we have some issues and questions.
I finished reassembly, plugged the old girl in, and pushed Air Fluff (to test the motor without heat) and she purred quietly to life. I opened the door to turn it off and I found out I've got a bad door switch. There was not a way to stop the dryer! I ended up flipping off the circuit breaker to stop the dryer. I turned the dial to Regular and pushed the dial again. This time it came to life, heated as it should, burned off the dust from the element, and ran like a champ. How long should it run empty before shutting off? Ours went several minutes before we flipped the breaker off and called it a night.
We are running it with a 3-prong plug. I did not connect a cabinet ground (might that explain the not shutting off?). Where is the cabinet ground screw anyway?
806 dryers are new to me,
Dave
Dave
