Warming my Cockles
The insulation contractor worked this week and finished up on Friday afternoon. The metal studs were capped top and bottom with hard foam and then topped with liquid foam. Several knee wall were also found in the attic and blocked. The energy auditor went in the garage attic after finding cold readings on the kitchen ceiling with its 9 can lights. The wall between the house and the garage was not finished, no moisture barrier, no insulation and no dry wall or wood covering. Last night was my first night in the newly sealed house and it was 14 degrees with a clear sky and full moon. The difference in comfort and no drafts was remarkable. I turned off the auxiliary heaters and let the propane heater work alone. For the first time since living here in the winter it actually began to cycle on and off instead of running non stop. I am very pleased.
