Defrost timer FSP 945486 KitchenAid Built In refrigerator
funktionalart
Jun 2, 2014
1,162
Rison, AR
Anyone up here familiar with these or have one installed on their unit? Mine is not problematic (that I know of, anyway--I just bought this refrigerator over the weekend. I currently have the timer removed so I can see how to set it (if that's even possible). Maybe they're just factory preset--Not sure. Right now, I'm just curious what their kick-in frequency/duration is--I've never had one of this type before--would just like to know what to expect. Pics below--FSP part number is 945486. 4-connection on wiring harness.
Many thanks!
Allen,
How old is the fridge?  Our 2009 KA Architect SxS doesn't seem to have a set schedule for defrosting, but I haven't actively tracked it, either.
My mom's '76 Coldspot defrosted every 12 hours.  It had a timer behind the front grille that could be manually advanced with a screwdriver.  I remember setting it to defrost during low activity periods like 2 AM and 2 PM.
Ralph,
My vintage stuff (the '63 Frigidaire and '63 Coldspot) both have that manually adjustable def. timer like you describe. It's what I'm used to. I bought this KitchenAid over the weekend, it is a 1989 model, 36" built-in.
So far today, it has only turned off once for something like 12 minutes. I'm sure I don't have to pay any close attention to it, just wondered if I have any control over when it turns on and off. Would be nice!
I put a few "beauty shots" below…although this unit is 28 years old, you would never know it. EVERYTHING inside still has factory "sheen" to it--almost like a never used unit. Nothing discoloured--seriously nice overall. Only a few minor/light scuff marks on the metal trim of a couple glass shelves. I was told it was in a guest house and only lightly used seasonally….it shows! $100 bucks. After moving this thing by myself, I can tell you that my chiropractor bill will be at least 10x the purchase price, though….
Defrost Timer On A KA Built-In Ref
The timer motor runs whenever the compressor is running, so the ref defrosts every 8-10-12 hours [ depending on which timer WP chose for this model ] the compressor operates, if you look at the tech sheet you can see how long this timer runs before defrost happens. The defrost period on a WP built ref is always at least 21 minutes.
This ref should only run around 50% of the time in an area that is around 70-80 F.
If it is running 70-90% of the time at normal room temps it has sealed system issues, but it is probably too soon to tell.
Thanks John--been watching it and it seems to be kicking for about 21 min. duration. Temps in freezer and Fridge sections have stabilized (I'm keeping at around 3-5 degrees freeze/38-40 fridge). Was mostly just curious about the timer being owner adjustable (or not) when I first posted…not a big deal. It works, I'm not messing with it!
