Dexter
I have a much older one from the late 40's early 50's. They are wonderful machines and you can do a ton of laundry quickly. I wash in one tub and rinse in another. One thing to be mindful of is to put a little bit of water in each tub and see if it will hold water without leaking out of the drains. To find a machine that has never been used is a true find.
Make sure you dry off the washer after you are finished each time, especially between the tubs on the flat surface, good place for rust to start. Have fun. Gary
