Larry,
I'm sure you're probably right. It was just a thought. The edge board connectors in the HOH are probably different than the SOH, right? I haven't messed with the HOH edge boards yet, so I was just making a semi-educated guess. Thought it might be easier to do than solder, if it worked. If one were to do the solder job wouldn't one need lead rosin core solder to match the old type solder? I have some and any time I do soldering on old equipment I always use the old type solder. It works much better, I think. The HOH will be in my future, if I ever find one. Have to find an electric. Don't want to mess with the front seal on a HOH gas dryer. It's too bad, we can't get those anymore. There's a nice one on C/L in Hannibal, but it's gas. Question. If one of the old wire wound baffles gets grounded to the drum, how does one know which wire to cut to which baffle to solve the problem, or is my thinking off?[this post was last edited: 6/21/2012-02:13]
