Dimming on the switch side to a different LED bulb is going to be tricky.
So is getting good CRI and color out of an LED.
I personally have Philips Hue - which is a very expensive system for lighting, not gonna lie - but dimming goes from very low to very high with no flicker and perfect color rendering.
Just that that's all done via their app.
Back home, we had very good experience with the normal Philips and Osram LEDs.
We don't have dimming there though.
The IKEA LED bulbs are very good as well.
A typical high quality dimmer should work with any high quality bulb that says it's dimmable.
All a "dimmable" LED bulb should in effect do is be a LED bulb that can run on a variable effective voltage AND monitor the input voltage and PWM the output accordingly.
Given though there is a lot of "in theory" there, going with high quality bulbs and high quality switches is really the best advice there.
There can and will always be weird quirks you can't really foresee.
That's really the biggest downside to LED lighting: Dimming and the compatibility there.
Next down the line is production and disposal impacts, followed third by high upfront costs.
