Dishwasher cabinet
cam2s
Apr 9, 2012
315
Nebraska
So I’ve been trying to come up with a way to have a second dishwasher in my kitchen without major renovations. I don’t necessarily need it to roll, but the unit will sit probably 3-4 feet away from the sink. I seen this cabinet on IKEA for a reasonable price, it doesn’t look Like there’s a countertop but I’m sure something could be rigged up. The question is will it be heavy enough to hold the dishwasher upright with the door open without anchoring the cabinet to the wall?
Electricity shouldn’t be a problem as there is a plug near the proposed location, wiring a heavy duty cord to the junction box will suffice there. As far as the intake water and drain is concerned, in don’t think a standard unicoupler will reach. I think I could take an intake hose from a Washer and use a female to female connector to extended the intake side and just clamp together an extra length of hose for the drain. Hopefully this won’t create an issue with the dishwasher being Able to function correctly.
As an Amazon Associate we earn from qualifying purchases.
have noticed on a few portables, there is a concrete counterweight mounted in the back to offset when the door is open....
Kenmore UltraWash's lower panel extended when the door was open as to prevent the machine from tipping over....
just a thought....
What he ^ said...my old Maytag had a concrete weight in it.  I'm currently planning on returning that old Maytag back to a portable but I no longer have the cabinet it came in so that IKEA one might work for me too.  I think IKEA used to sell a specific DW cabinet a few years ago IIRC but no more.  Martin, do you know how much those counterweights weigh?
Extend the front of your cart...
<span style="font-family: helvetica;">I have a number of BI dishwashers that I have made carts for.  I just extend the front of the cart a few inches and bolt the machine to the cart.  I can have both racks fully loaded and pulled out with no tipping.  This is the first one I built but I've learned I really only need to extend a couple of inches so subsequent ones didn't stick out this far.
Where I would like suggestions is what to do about the sides. I have collected a few of the kitchen aid butcher block tops over the years and so far they have all fit model to model. I don't show it in this picture. I'm just not sure what to do about the sides. I'm not sure about that cabinet from Ikea unless the open end goes on the bottom. I'll be eager to see how that works out.</span>
[this post was last edited: 12/29/2020-06:27]
As its on a cart
Could you make it slightly wider than the machine and that would enable you to panel the sides?
Can you get some white shelving wide enough to cover the sides and fix to the cart and the butchers block top ??
Just throwing it out there :)
Austin
Thanks Austin
<span style="font-family: helvetica;">I may try something like that.  All my converted machines are stored right now but I thought about something like some bead board.  You're idea may be more sturdy but I may need to increase the size of the cart just a little.  If I take the time to do that I will also reduce the amount in the front of the cart.  I don't think it needs to stick out quite that far to avoid the tipping.  The one I have in the house right now it a full fledged portable.</span>
