mike_g
Hello,
I've posted here in the past, talking about my 30 year old kitchen aid DW, that, alas, recently went to its grave. This was due to the purchase of a new Maytag DW, MDB8969SDM0 which I suspect will last maybe 5 years, instead of 30. We call that progress. I digress!
We have hard water, about 13.7 grains, or 244 mg/l if you prefer.
With the new (2 years old) DW, we have been using cascade complete powder in both cups, and the "power blast" cycle, which runs for about 3 hours and uses about 9 gallons of water. We often use the sanitize option which boosts water temps. We use jet-dry in the rinse aid dispenser. We found that adding about a tsp or better of "lemi-shine" to the cascade in each cup helped it clean better, and so have been doing that for a year plus. In the past few months, granular deposits have been showing up on the dishes, little white deposits that apparently didn't rinse off fully. The cleaning action is generally worse than previously, especially in the top rack.
There is no stand-alone filter in this washer, just an accumulator below the wash arm, which shows a little white buildup on the fabric screens. I wasn't able to remove the accumulator for proper cleaning, due to not knowing how to remove the upper wash tube.
This has had me on the path of researching homemade dishwasher detergents with phosphates. I've read a number of posts on this sites and others, which have been much help, especially the post with info on STPP. Does anyone have a good recipe for either a homemade detergent with STPP, or a recommendation on commercial detergent plus STPP? Maybe it is best to just use Cascade Complete + STPP at a 2:1 ratio? Also, I've read about the Cascade Fryer wash out soap, but that stuff is about $16/box at Amazon...pretty expensive to me.
