<span id="internal-source-marker_0.5582064753398299" style="font-size: 11pt; font-family: Arial; color: #000000; background-color: transparent; font-weight: normal; font-style: normal; text-decoration: none; vertical-align: baseline; white-space: pre-wrap;">My Miele Dw does it before the pre-wash if you are running a program cycle with one, or it will be at the beginning of the main wash if the program cycle you select does not have a pre-wash. </span>
<span style="font-size: 11pt; font-family: Arial; color: #000000; background-color: transparent; font-weight: normal; font-style: normal; text-decoration: none; vertical-align: baseline; white-space: pre-wrap;"><span style="font-family: Arial;"><span style="font-size: 11pt; font-weight: normal; white-space: pre-wrap;">It has run 15 cycles, then regenerate for water hardness between 9 and 10, 10 cycles then regenerate for harness at 16, but this last time it went 6 cycles then did a regeneration but the hardness it is reporting was 21. Today the hardness reported was 19. It reads the hardness during each fill so you don’t have to set any selector. It might be using some type of sensor to determine how much calcium has built up in the resin, but I don’t know. For some fills, in some cycles, the DW directs a portion of the water around the softener(bypasses it)and this unsoftened water spills into the tub on the left side. I think it does this so the water does not get too soft and cause glasses to etch. The dishwasher has a part named the "water inlet mixer" located on the left side of the machine which is about as tall as the dishwasher. This part has multiple connections to the electronics and this is the part that, following the directions from the electronics determines where the incoming water will go; to the salt reactivation reservoir</span><span style="font-size: 11pt; font-weight: normal; white-space: pre-wrap;"><span style="font-family: Arial;"><span style="font-size: 11pt; font-weight: normal; white-space: pre-wrap;">, through the softener, or around the softener and into the left side of the tub. It also measures the water hardness before the water reaches the softener so that it knows how to mix hard and soft, and it measures how much water has entered the machine during each fill so that the machine knows how much water it has </span><span style="font-size: 15px; font-weight: normal; white-space: pre-wrap;"><span style="font-family: Arial;"><span style="font-size: 15px; font-weight: normal; white-space: pre-wrap;">initially drawn for the fill. It may draw more water based on the size of the load, but it uses this initial amount as a starting point. Some cycles such as the "Normal" cycle start with more water than others. The water softener resin is located at the bottom of the inlet mixer and it is also connected to the electronics .</span></span></span></span></span></span></span>
<span style="font-size: 11pt; font-family: Arial; color: #000000; background-color: transparent; font-weight: normal; font-style: normal; text-decoration: none; vertical-align: baseline; white-space: pre-wrap;"><span style="font-family: Arial;"><span style="font-size: 11pt; font-weight: normal; white-space: pre-wrap;">Normally when you turn the machine on the drain pump starts immediately and will run for a few seconds, then it will begin to take water for the fill. When the softener regenerates as soon as you start the machine, the water starts flowing in while the drain pump runs. It will take some water, stop the fill, take some more water, stop the fill, take some water, stop.... The drain pump will continue to run during the entire time. I don’t know for sure but I think it is running the water through the salt container and then forcing it through the resin....and then it is being pumped down the drain. None of this water touches the dishes. The process lasts about 2 minutes, then everything will stop. Then the pump comes back on and it is at the beginning of the pre-wash like usual. My previous Miele used lights to indicate the part of the program cycle it was in and it had a light that said softener so you knew what was going on. This newer one just says prewash or wash as if nothing special is going on but because I had a previous model I realized what was </span><span style="font-size: 15px; font-weight: normal; white-space: pre-wrap;">happening</span><span style="font-size: 11pt; font-weight: normal; white-space: pre-wrap;"> This one doesn't take as long to do it as the older one.</span></span></span>
[this post was last edited: 2/11/2011-23:12]
