Possible timer issue?
Just finished another load in the dishwasher. Looks like this is still our primary dishwasher until our Kenmore gets fixed for the third time, the wrong part was installed.
I ran a cycle on normal with High temp boost selected and I ran into something pretty odd, after the final rinse It should have done a 37 minute dry. Even more oddly though, I was timing the dishwashers normal cycle which is 85 minutes as stated by a previous poster (1 hour and 25 minutes), but the cycle ended at 1 hour and 06 minutes INCLUDING THE DRY TIME. I'm pretty sure the dishwasher went into the dry cycle at 50 minutes on the timer (on my phone) and then I went back up. Couple minutes later to come check on it i notice that it's already on the off position...Huh? I then figured out that it only stayed on dry for 16 minutes...no wonder everything was wet.
So I ran the dry cycle again but this time, it went for 31 minutes and everything was bone dry this time. Could this indicate that the timer is moving to fast?
