Do towels go mouldy at 40?
Low blood pressure, or hypertension, is basically caused by poor blood distribution in the body: when you sit up after lying down or stand up from a sitting position, blood pools in the leg veins and for a brief time less blood flows back up to the heart and brain. This slight, temporary shortage of blood flow to the brain causes blood pressure to drop. Weakness in the heart muscle or insufficient tension in the blood vessel walls can be responsible for low blood pressure as well. Those affected suffer from spells of dizziness, rapid or altered heartbeat and blackouts, often upon getting up suddenly or after standing for a long period. Signs of low blood pressure can also include fatigue, paleness, sweating, inability to make decisions, sleep problems and difficulty concentrating. Symptoms may worsen when there is increased blood flow to the skin; this can occur after working in hot sun or with a fever. Fortunately, a number of natural and home remedies can ease symptoms and improve circulation
that should explain it :)
Tom :)
The roughness of the towel rubbing against the skin, causes blood too
circulate through the veins in your arms,legs,feet normaly, thus improving blood circulation :)
my sister works as an O.D.P in Llandock hospital in Cardiff, she explaind to me how it works but i forgot moast of how it works, i think ive coverd the baisics :)
I started going mo(u)ldy at 44. It got much worse at 60.
Telling a 40 they can't be 'proper' below 75 is like telling Campbell's their soup is too salty. It is, but that's how customers like it.
Everyone has their notion what's going on in laundry, like above 'cold is too alkaline' when temperature has absolutely nothing to do with pH. I doubt even a PhD surfactant chemist could change their beliefs.
Toweling does help blood circulation...,
but not because the towel is either rough or soft. It is the action of toweling, which is a form of physical activity, that promotes blood flow. You are using the muscles in your arms and upper body when you are vigorously toweling yourself, which makes your ticker work harder to supply blood to your muscles. The roughness of the towel adds to the overall sensation as it stimulates the skin.
Another way of stimulating peripheral blood flow is to alternate hot and cold whilst showering. It is a very invigorating way to start the day and prevents those little spider veins that keep popping up with advancing age.
I have rashes on my skin so...
... a soft towel is good for me! Thats why in the dryer I use low heat on towels so they don't come out really hard. On the Bosch, an Express 60 is good for towels, then 45 minutes or less in the Creda!
Thats how I now wash towels!
Jacob
Towels are always washed on a cottons wash at 60oc, usually with steam wash selected in the LG. They stay fresh for a longer time, although I did experiment by washing a few dark towels on cottons 40oc just the once with steam wash selected and they did come out just as good, but could be becuase they weren't soiled much.
At the moment i've just put a white throw and two white towels on a cottons 95oc :) My first boilwash in the LG!
Here at this part of the globe it's so normal to do everything on cold water only that only a few models have an nternal water heater and much less have hot water inlet.
Most people would say "what? hot water to do laundry? why?" Even many commercial laundries don't have hot water supply (except those that do laundry for hospitals) and as far as I know, nobody here have mouldy towels or dirty clothes.
Maybe our detergents are years beyond the rest of the world when talking about cleaning on cold water? Maybe our cold water isn't cold enough? or maybe brazilians have a different DNA from the rest of the world and our bodies are self-imune to some kinds of bacterias and germs... Maybe something in our water reacts with the detergent and boosts it.... only God knows.
As a laundry addict, i always washed my whites on hot water (60C) and then suddenly started to wash the towels and sheets on hot water too. the only difference i noticed was all the colored towels fading, so i went back to cold water.
With other detergents I decided to try cold water also on whites and.. the result was even better! My whites were always perfectly white using hot water, now they are spanking white, like new, using cold water.
one of my machines runs exclusively on cold water. I tried to fill it with hot water once, using a hose, but the heat engages the thermal clutch and makes the machine spin full of water instead of agitate. It doesn't have a single trace of mould
Coincidently I've done laundry in Europe and in the U.S., and the times I tried to use cold water I always got horrible results and had to rewash everything on hot water.
I wish I could have a clue why some washing techniques work in some regions and not in others.
Same about mould in front loaders. It's almost impossible to find mould in a washing machine here. Smelly tubs, are almost unthinkable, unless the owner is stupid enough to keep the door fully closed after the wash day.
Water in Brazil is so soft that most people never heard about hard water.
When I say "hard water", some people here laugh and say "duh, hard water is ice. you mean hard water because it's so cold there that water freezes in the washing machine, right?"
average "cold" water in my building is between 25 to 35 degrees during the summer (with the chiller on). If the chiller is off, it can heat enough to cause burns and make the faucets start to fart steam. but obviously it's an isolated situation and we don't say the water is cold in this case.
usually, the cold water is ok to fill the tub and take a decent bath without feeling cold, but it also doesn't feel warm. on the hottest days i tend to throw a bucket of ice in the tub, otherwise i'd start sweating while bathing.
Some people don't believe I can dry a bobload of jeans or towels in about 8 minutes in my affinity Electric dryer. Sometimes the cycle starts with the 5 minute countdown and then go straight to the cool down, without showing that spinning sign on the display. When they come to Iguassu, the airplane door opens and they instantly understand how it's possible. it's not warm.. it's fu**ing HOT and dry. it's like stand in front of an industrial oven and open the door.
Take a look at my picture.. With this "paper bag" color, Can you believe my father is spanish and my mom is german both so white that look like bleached? I'm not blond or have blue eyes, but if I spend a month out of here, I'll be as white as paper .
