Do You Agitate, Shake ?
mrboilwash
Jan 30, 2006
1,486
Munich,Germany
Out of habit I flip over any bottle of liquid detergent, fabric softener etc to make sure that all ingredients are well suspended. On the contrary I see no point in doing this when handling dish soap or things like all purpose cleaner.
The only time I have actually seen a deposit at the bottom of a bottle was an older version of Ariel and the Pod-type Persil that doesn`t look homogenous, but I could imagine they don`t require the extra chemicals to keep things well suspended because you are not supposed to use less than one pod.
Also whenever I have to rinse a dosing cap with water, I would flip over the bottle to "charge" the cap with the product`s preservatives in the believe to expand it`s shelf life.
Do I need professional help or am I just a little more anal than others ? [this post was last edited: 12/12/2012-07:27]
Ditto the above. We also give new boxes of powdered detergents a good shake before opening them, probably for no reason whatsoever. :)
I've been using Clorox Green Works liquid laundry detergent. It's very gentle and leaves towels fairly soft. It's clear green, of course. When I got to the bottom of the first jug, I noticed that it got thick and cloudy. For the next jug, I've been inverting it and shaking it a bit from time to time, to keep whatever "goodness" is in the cloudy part suspended. So now it's a kind of pearly green.
Haven't found the need to do that with fabric softener, though.
It's a good idea to shake a bottle of salsa before using it. Also good idea to shake a can of evaporated milk prior to opening.
