Does anyone have a Maytag AMP washer and dryer set?
maytag85
May 11, 2017
3,049
Sean A806
I know there are Maytag AMP washers out there, but does anyone have a Maytag AMP dryer? Are there any pictures of the inside the dryer AKA "the money shot" ? Were Maytag AMP dryers vented, or were they condenser dryers?
The dryer I saw that matched a 1954 model, the washer with the small back console and two knobs, was a condenser dryer that hooked up to the cold water line and drain.
MAYTAG AMP WASHER & DRYER
I HAVE A SET OF '56 OR'57 AMP'S. I WILL MAKE A PIC OF THE INTERIOR AND POST FOR YOU. I ALSO HAD A SET OF FLAT TOP AMP'S THAT I SOLD TO ANOTHER MEMBER. BOTH DRYERS ARE GAS WHICH ARE VENTED. MAYTAG DID MAKE A '56 - '57 DRYER THAT WAS A CONDENSOR. JOHN L. HAS ONE.
BOB
I had an AMP/60W set for a short while and sold them to a long-time member of the board.
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?30848
The 60W was the first Maytag dryer produced (in 1953) and was a condensing dryer that utilized a water valve and pump to circulate the water for the condensing process.
Shortly afterwards Maytag came out with a standard air blown electric (60C) and gas (70C) dryer that Matched the look of the A2MP/A3MP, but the 60W was the only dryer to have the matching "Maytag" emblem on the front and knob/timer dials.
And, someone else found an A2MP and the 60W dryer in a basement a few years ago. Pretty cool!
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?48991
Ben
Original Maytag automatic washer and dryer
We have a pair of these at the museum the dryer is the condensing electric, as Ben said when they change the emblem in the knobs from white plastic to metal they also had gas and vented electric versions with the flat top.
As far as how well the original condensing dryer works I don't know I've never tried to run mine and I've never known anybody that use the original style , I did hear that Maytag out a lot of fires with him though if they weren't maintained properly
I guess Maytag decided to eventually switched to the 640C/740C design in 1956, and then to the Halo Of Heat design.
