Does Anyone Know this Guy?
mrmom
Jul 27, 2016
14
LA Calif
Hello all
I ran across a thread # 4533 The guy that started it was Totalnewb his name was Steve
If you look at the thread he reproduced the dial for a A606 with permanent Press in Adobe Photo Shop I saw his handle is no longer highlighted so I could not send him an email He offered anyone a copy if they wanted it. Did anyone take him on it. Does anyone have one they could send me or how to get in touch with the guy I added a picture of his dial he made
Thank you for your reply's
Fred
Hello
I figured I asked for this so I would post a picture of my knob. I used the above picture. I used a blank UPS shipping label from work. They come two to a sheet 8 1/2 X 11 so it goes right thru your color printer. There a litho paper so it does have to be sealed. I just cut it in a circle about 1/8" larger then the inner circle I cut just inside the line, Then cut from inner circle to the outside right along the off. Then I peeled off the liner, I started at the opposite side, When it came around to the slit it over lapped so I used an exacto knife and trimmed it to fit right next to the off, Once it was down firm I used the blade around the outside like trimming a pie crust. I took my finger nail and followed around the inner chrome to leave a dent then took the exacto knife to slit the center out. The paper is real absorbent so I misted it two times with clear so the ink would not run. Once that was dry I hit it 6 coats just to make sure. So far it has been on for over three weeks and Spray and Wash hasn't hurt it.
