Honeycomb care and cat hair
overflow rinsing
Hi Robert
Thanks, yes I was thinking of overflow rinsing in the Frigidaire - that's why I specifically mentioned that washer.
It's in storage in the garage at our old house, where a relative now lives. It will need some TLC to get it back in action, that will happen soon.
turbo vacuum
I won't be using a turbo vacuum attachment to vacuum my clothes - that's what washing machines are for!
I did try vacuuming my top sheet, the problem one, with the Bissel Pet Hair Eraser upright vacuum cleaner - one I scrounged from the dumpster behind a store, its fault was brush roll not turning, only required a 10c resistor to fix. It wasn't very successful - the cat hair remained largely attached to the sheet, and the vac wanted to eat the sheet. Once the cat hair has been washed, it seems to go into tiny balls that cling hard to the fabric.
"Idea is that the hair won't spread onto other items or loads.."
Well suppose that could work, but long held wash day wisdom states among other things sorting out what produces lint from what does not.
Wouldn't dream of putting something full of pet hair or any other sort of fluff into a regular load as is so to speak. It is just a formulae for disaster. Using a clothes brush, lint roller, cello tape, vacuum or by whatever means major part of fluff/hair is removed from item before it goes into wash. This or offending item is laundered on its own by various means.
Fluff, pet hair and other bits are where solid tub washing (by machine or hand in tubs) shines. Because one is lifting wash out of water (instead of latter draining through laundry) fluff, hair, and so forth become less of an issue.
If doing wash by hand in tubs creating an "agitated overflow" rinse also works wonders. Have been doing this with black jersey pulls and other garments for some time now.
You have to make sure whatever clothing or soft items your vacuuming is attached at the corners so the suction won't suck it in. Opening the suction control takes some of that pressure off as well.
I think we can agree that using a scuzzy junk found upright that needed a belt and had no functioning rotating brush is going to be a failure.
No, it is not the job of a washer/dryer to remove large gobs of lint or hair from clothing.  The owners instructions specifically state that.  A washer is intended to remove mainly liquid, or easily liquified soils such as body secretions, grubby dirt from daily activities, and food stains.
If your going to have a pet, you need to have the tools to care for them.  An animal that is free roaming will require an appropriate vacuum cleaner with beater bar for carpeted areas and a mini turbo attachment for any surfaces that an animal is allowed to dwell on.
I stayed with a friend a while back that had one of those huge dogs that sheds profusely.  Oh my lord.  All the dog had to do was lay on a freshly vacuumed rug and the area would change to the color of the dog.  It shed that much.  One had to clean the beater bar on the vacuum after each use it would simply clog up that fast.  Can't imagine the amount of pet dander and other bugs that would attract.
Cats are just as bad.
Don't know about all vintage top loading washers being great at fluff/pet hair removal.
One reason let our vintage WP convertible/portable washer go was that fed up with lint. Neutral drain did nothing for one either, and was that fed up with things (especially darker colored or blacks) coming out looking dreadful. Not even trip through dryer removed everything.
Of course that washer only had the "Magic Mix" brush combo filter and dispenser.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?33598
Maybe other top loading automatics had better filtration systems.
"scuzzy junk found upright" - response to #23 above
Well excuuuuuse me!
The upright in question was a warranty return of a nearly new machine. It is as new. It is certainly not 'scuzzy."
I have been rescuing/repairing appliances for over 30 years. When I have repaired an appliance, it works perfectly. It is also spotlessly clean. No repaired appliance is allowed in the house till I have dismantled it and cleaned it inside and out.
To make it perfectly clear, the Bissel vac was working perfectly when I tried vacuuming the sheet. It was repaired a year or more ago, long before we acquired this lovely cat. I only mentioned the vac's history as an aside, I thought it might have been interesting. I thought it was probably plastic junk when I first got it, but it has proven me wrong. It is a very good vac, seems to clean carpets as well as the Kirby G4.
You discussed "a level of hostility that comes out" in another thread, yet you make a rude comment like this. I wasn't asking for a critique on how I source appliances, I was asking about a premium quality washing machine that appears to be particularly crap at removing cat hair. My washing doesn't have "great gobs" of cat hair, some few items have a few fine hairs on them and they seem to remain attached to the items being laundered. I have had cats and washing machines for decades, never had this problem before. The instructions do NOT mention anything about pet hair having to be removed before washing. It only states to remove anything that might damage the machine, like keys, coins, etc.
[this post was last edited: 1/18/2022-21:51]
Chis, I have no idea what, or more specifically, who you were responding to.
That's not a complaint.  It's an endorsement for the "hide" feature that makes viewing any posts made by chronically rude people a thing of the past.  I highly recommend it for ensuring that any visit to AWO is a pleasant experience.
I was responding to the comment in reply #23 that referred to "scuzzy junk found upright." That's why I started with quoting that text in the heading in red at the top of the post. (labeled "subject drift" on the add your reply page.) I've edited that heading to make it more clear.
No problem at all with your reply above, Ralph.
Just going off what you stated
You did state a vacuum that "...I scrounged from the dumpster behind a store, its fault was brush roll not turning..."
if that's the case how is it now "... a warranty return of a nearly new machine. It is as new." ? Maybe they do things different regarding returns in Ausie-land?
But I do appreciate, as I've done more than my share: "I have been rescuing/repairing appliances for over 30 years. When I have repaired an appliance, it works perfectly. It is also spotlessly clean."
And it's always a good idea: "No repaired appliance is allowed in the house till I have dismantled it and cleaned it inside and out."
We're all just trying to help you with the lint/hair issue.
OK, maybe I wasn't clear enough.
I did say I'd fixed the vac with a 10c resistor, I didn't explicitly say it was fixed <span style="text-decoration: underline;">before</span> I vacuumed the sheet - but I had.
No, I haven't changed my story, so I'll make this clear.
I live out in the sticks. I drive 1.5 to 2 hours to town to do grocery shopping.
There are two stores in a town near me that have skips (dumpsters) behind the store, I have asked them both for permission to retrieve things from the skips (dumpsters) and they have agreed. This is an unusual arrangement here, usually trade ins and returns are kept secure from the public, probably due to liability concerns. They cut the power cords off many, but not always. I can fit new cords. The Bissel vac had its cord unharmed.
They sometimes have new or almost new small appliances in them, I can only assume they are warranty returns. One (a toaster) even had its price sticker still on it, so it must have been an ex-display toaster, sold unboxed. (as another aside, this toaster's fault, as I could see it, was that it tripped the earth leakage breaker. (RCD.) The actual fault was a raisin stuck inside, shorting the element to the metal frame inside. Remove raisin - toaster fixed.)
Because these stores are both in the one town, and the town is a long way from the city and thus from the manufacturer's warehouses, it appears that the manufacturers don't want the items returned for inspection, it isn't worthwhile them paying freight to transport a broken small appliance a long distance just in case it might be repairable or not faulty. This means inevitably that some small appliances like vacs, toasters, coffee machines are going to be discarded in the skip when there is only a trivial fault, or occasionally because the buyer is an idiot and the item isn't faulty at all. The store staff don't want to get into an argument with customers, they hand over a new gadget, bin the returned one, the manufacturer or importer replaces the gadget and the customer goes away satisfied. It builds goodwill in a small community.
Big stuff like washing machines will be inspected/repaired under warranty, but I have also salvaged some good recent model washers, such as a 3 or 4 year old Bosch FL which only had a pump full of pet hair stopping it. I fixed it, cleaned it and gave it to a friend who runs a wildlife rescue shelter - it now washes blankets for orphan kangaroos and wallabies. Its new owner knows how to clean the pump filter...
Maybe I should get myself another Bosch, it seemed to get pet hair off the washing and into the pump...
Any way, maybe we can let this thread die now.
I will eventually resurrect the Frigidaire and use it for overflow rinsing. I might also try another front loader with bigger drum perforations - I have a few. All rescued from the dreaded crusher.
Best automatic washers for removing pet here
Far and away the best machines ever were the old combination washer dryers with a huge number of large holes they had in their cylinders. Other machines that we’re good we’re older front loader Westinghouse is with large holes in the baskets again.
My 15 year old Speed Queen frontload machine does a good job, but the two year old Speed Queen has fewer and smaller holes it’s not as good.
Top load belt drive whirl pools were also very good at removing lint and hair. From clothing.
The Miele machines with the honeycomb drums are ridiculous they don’t even get dirt out of the clothing like sand etc.
The overflow rinsing in solid tubs is not particularly effective either,hair is heavier than water so it does not float out some of it is washed over but it’s not that effective.
John L
Having the luxury of a Whirlpool Dreamspace and SQ dryer
Down in the shed I use these for all pet bedding and anything covered with hair.
After a wash and dry is done the hair is in the filter and maybe a few in the crease of the door seal but nothing to write home about, I just stopped putting anything hairy in the Miele.
As the ad says... "Simples"
Unsure of name
But there are bags you can get that you can put hair covered items in before you wash it the hair is meant to stay in the bag you simply shake outside afterwards, I guess they would be better than a ruined clothes washer.
Austin
Have a Hotpoint twin tub
Which has a filter on the top of the agitator with a recirculating pump and that is absolutely brilliant at removing any hair, am always amazed at how much is collected at the end of the wash.
Austin
Pet hair does float!
The solid tub GE Filter-Flo washers also are great at removing pet hair as it is recirculating over the top of the tub for the full wash and rinse cycle. When I've had items with heavy pet hair this machine got 99% in one washing.
The early machines AW6 machines with the self-cleaning filter rings also work the same way and get the majority of it out especially with the hair going down through the center of the agitator into the outer tub and back up to the filter screens.
3 cats and 1 dog inside...
2 of the cats have long hair and one has short hair, but they all shed a lot! I have a Maytag mvwp575gw (it's a vmw washer, but it has a dual action agitator) and an LG dryer (went with an LG front load washer). I use hot water, a good detergent, and usually Lysol laundry sanitizer (but sometimes bleach).
I wash the dog and cat bedding by balancing it with something like a towel using the Powerwash setting with a presoak (no extra rinse). I haven't had any issues with pet hair collecting in the washer. The pet beds are too large to spin dry. So for these loads, I usually run the dryer for the full time on the same setting I'd use for towels. This dryer also has an anti-bacterial option. I just clean out the lint filter after each load.
When I had the LG front load, I would use the sani-wash setting or something like that. Worked awesome for removing the toughest odor. I don't remember hair collecting inside it or the pump either.
I'm not sure I'd want to put those pet beds in the dryer first. The dog one definitely gets an unpleasant dog odor that I wouldn't want to get on my freshly washed clothes.
For what it's worth, this Maytag washer will be four years old this summer with no issues.
Pet hair floats?
Take a handful of pet hair take some lint while you’re at it put it in a quart jar shake it up and check it the next day 90% of it will be sitting in the bottom of the jar it is heavier than water.
Yes it does not sink quickly, and during agitation it stays pretty well in the water but it doesn’t naturally just go to the top and over and out.
John L
Just for removing the lint
Perhaps getting an older, used dryer, that maybe the heater doesn't work on any longer, and use it strictly for it's tumbling and filtering benefits BEFORE washing the item normally in your washer.
Then you can use your current dryer to finish.
