Aqua Stop
Also protects against a busted hose
On the Miele version anyway, you have a double solenoid that screws directly onto the tap. If Grit blocks 1 solenoid open the other should still stop the water flow.
Likewise if the inlet hose bursts, the water should run into the sump of the dishwasher and trigger the float, or in a total failure, the machine should time out and stop filling after after a preset time.
The Bosch must have an unusual setup, because if the water level got that high in the Miele, that the water was running out around the door seal, there would be way to much water in there in the first place. The Miele detects an abnormal overfill (IE a bowl tipping over) and will cancel the wash in case it is a leak. The Bosch system mustnt be as advanced.
