B brett New member Joined Feb 11, 2022 Messages 0 Location Sheffield Feb 11, 2022 #2 I recently replaced my pump when I put it back together I can't get the door to shut. It appears the alignment is ok. Any suggestions
super32 Well-known member Platinum Member Joined Sep 5, 2004 Messages 884 Location Blackstone Massachusetts Feb 13, 2022 #3 Make sure the lock is not in the "closed" position. If it is, you should be able to use a paper clip to flip to the open position.
