drain pump for 18" GE d/w
firedome
Jul 21, 2011
2,626
Binghamton NY & Lake Champlain VT
PhilR has been visiting and while here, besides talking about Frigidaires (of course!) and checking out our new Whirlpool stacker set, we've been trying to diagnose a problem with our compact 18" GE (Danby?) "made in China" dishwasher. with an old school mechanical timer and on/off dryer switch.
The main pump and inlet valve seem ok, and the timer is working. The problem seems to lie with the Hamming drain pump. It's impeller spins but seems a bit reluctant when disassembled, but doesn't seem to spin when together and powered. The part is # 5304461725. The d/w is model GSM1860NSS. The part is available on the 'net but super expensive. Anyone have a good used one, or know of a reliable discount source? The one cheaper source is a 3rd party drop shipper, are those legit/'safe to use if there's a problem? Seems like there's no parts houses around in town any more. Thanks for help!
Drain pump for Chinese 18 inch dishwasher
Hi Roger, it’s GE part number WD 26X10021, GE says it is no longer available. It would probably be pretty easy to match something up if I had the old pump.
There is one under that part number on eBay right now for $35 including shipping for a used one, they don’t fail that often the most common problem I see with that model dishwasher is there something caught in the pump? Have you disassembled it to see if it’s jammed
Let me know if I can help, John
thanks John...
I wasn't sure if the eBay one was the correct part. Does it look right (see pics)?
Otherwise if you send your snail-mail add'y to: firesweep (at) verizon (dot) net I'll mail it off to you.
