Dream Machine: WWA 9500L
Well, I received one of these recently from a seller in Georgia along with a mate. The shippers very efficiently called me when they were down there picking up the machines and warned me that there were some problems with them. I wanted them anyway, because I coveted an all-blue washbasket and wanted them, if nothing else, as parts machines for when the real things come along. First off, can any GE experts here spot something wrong in this picture?
We'll table that for now and get to some real problems
The big problem with this machine is that it agitates, in both speed selections, the timer advances water is injected at the proper times and even the bleach dispenser solenoid opens and closes according to the intervals indicated in the schematic...
but it doesn't spin.
When I move the control dial to any of the 4 spin periods on the dial...Nothing. No sounds whatsoever and no indication that power is moving anywhere in the unit except for the timer because the spray rinse happens when the dial advances.
Any suggestions before I start to take this thing apart? What has gone ka-flooie when a machine like this agitates and operates in every way except for doing a spin/drain? Partial motor failure? Broken centrifugal switch? Broken winding? Broken cam control? Help!
could be wrong, but weren't these machines something like a 16lb capacity, if thats the case, that filter pan is the wrong size, and chances are the agitator is not original...
clothes guard might be missing as well.....
(wrong answer buzzer sound)
EHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!
The last 3 Programmed Washer models were "Heavy Duty 18" large capacity models with the "Super Filter-Flo" pans. I would LOVE to find the last 1972 model.
sorry posted before your next post.....so this is an 18lb machine....
the only other thing I can think of, but again, not sure when they changed the lid hinges to these plastic designs...
other than that, I am stumped.....
I'm with ya Ken - that blue tub is just the bees knees!
I've had a similar issues when playing with GE's, and it usually leads to the lid switch.  These motors don't use a centrifugal switch, but instead use a motor starter relay.  Since the motor works in agitate I'd take a stab that the relay works fine.
I just re-read the thread, and you mention that it sprays during the spray rinse?  That's interesting.  Maybe check for voltages across the appropriate leads to the motor during this time to see if it is getting any.  Hopefully you have some spare motor/clutch assemblies on hand....
BTW - you posted a shot of a'68 TOL panel the other day, with the back-lit timer dial and program selector labels.  That would be a find!
Ben
Martin wins!! (the sound of the correct answer)
DING!DING!DING!DING!DING!
They didn't change the hinges on domestic machines from the metal ones to the plastic ones with the visible lid switch until 1972.This machine is a 1970 model. I first saw the new hinges on Laundromat models in 1971 and I was thrilled because finally that pesky Filter-Flo safety switch could be defeated easily. I suspect the entire cover and lid of this machine is a replacement. I think these machines were used by renters; they have many signs of abuse.
Speaking of the lid switch, yes, I checked the lid switch first and did a by-pass to prove that it wasn't' a defective switch. Now, I suppose, I have to trace the leads back to the control cam and the relays to see if there's a break in any of the wires or if the relay itself is faulty. If the relay were faulty, wouldn't the agitation not work as well?
Sounds like maybe a loose or disconnected wire. The lid switch isn't like the Whirlpool which allowed itself to agitate a while with the lid open. The Maytags and GEs did nothing at all but fill with lids opened.
not entirely true....GE FilterFlos used to wash with the lid open, and had this machine have its proper top, that should be the case, even if they switched the top, they didn't switch the original wiring......
granted it is possible of operation only when the lid is closed, but I think that revision for those models was more towards later in the 70's lineup....
my mother used to like her V12 that 'only spin with the lid closed'....it allowed her to set up a semi automatic soak, if she propped the lid slightly open so it would not spin...
Non Spinning GE FF Washer
The timer switch with 5 leads is the motor reversing switch, this is where I would check next. The 5 lead switch is a little tricky to remove, you must partly open up the timer halves to get this Sw in and out without breaking the fiber terminal spacers.
One of my fave GE models
Always fun to have a new GE - did you get the matching dryer too?
Our 72 GE washer would fill, agitate and even spray rinse with the lid open. No spinning, but on a full water level the timed spray rinse is enough to get the water level above the overflow tube. "There's water on the floor again, who left the washer lid up?" I wonder...
John- Exactly HOW does one open up the timer halves "to get this Sw in and out without breaking the fiber terminal spacers"???
Greg-Yeah, I have the matching regular capacity dryer, I'll do some posts on that soon because the dryer has some issues as well.
Martin-You're right; up to the Eighties GE safety switches only interrupted the spin; later on they stopped agitation, but not, thank you, fill.
After examining the electrical schematic, I noticed that the one of the 2 leads from the lid switch terminates in the "SOAK" option switch. The bank of small buttons that comprises the SOAK, COLD WASH & EXTRA RINSE selectors on this machine is frozen solid and may be the culprit. I'm going to check that next and see if I can get those buttons unstuck and moving before I think about cracking the timer case open. It really does feel like a switch problem.
Wow, Ken, this is a cool machine for sure!  I hope the problem is not too serious...  If you have the service manual for this, they should have a timer testing procedure to check that the switches are working properly (the info I have for the 57 FilterFlo has a really detailed procedure and even explains how to build a testing tool!)
Keep us posted!!
What John just said:
Exactly!
If the options selectors are frozen with SOAK selected, it would explain the problem. I suppose this switch is meant for the EXTRA RINSE/SOAK section of the dial, but if you put the dial anywhere else everything would work except for spin. Makes me wonder if you did this, would the machine overflow like Greg's Mom's?
Keep yer fingers crossed! I really hope this solves the problem, but I may not be able to repair the switch bank.
I'd really like to find this model(the very last Programmed TOL; I already have the dryer):
