dream washer
pierreandreply4
Sep 7, 2007
2,691
St-Bruno de montarville (province of quebec) canad
here is my dream washer dryer set 1 set is white pic 2 pic 1 washer is almond colored but thats a minor detail for me but i wonder what woulkd be the liquid fabric sofner that go on the agitaor but my biggest question is how to convince my mom that for or needs a used refurbish as new washer like the kenmore in the pic would fit or needsDream set1.jpginside of dreamset 01.jpg569c82b0-eb1b-49f7-8992-ae83ef2fd34f.jpg
It is truly everything someone could ever want or need in a top load washer minus the auto detergent dispensers and hot/warm. These washers were the best built washer ever over-all. They gave you everything, cleaned well, were reasonably durable and lasted. While I would trade anything for a new in box dependable care set, I honestly would not mind trading my Speed Queen for a new TOL late90s / early 2000s Kenmore set.
i wish they would bring back true direct drive topload washers brand new in stores to sell i did laundry today i had set the washer to warm wash cold rinse did not even fill with warm water and i never know when my curent washer will pop fault code F3E3 when its already showing a bad control board fault code F0E4, i think my curent washer is a lemon i even gave up after alerting my mom that we should have the washer check by a tech. What will it take to make my mom realise we have a cheap washer and i think my mom back in 2021 when we bough or curent set my mom should of lisen to me when i told her sig about huebesch speed queenHB-TC5-Thumb.pngsigh can not go back in time
Pierre, if everyone were like me this is what Speed Queen would look like in 2025. With a metal timer, yellow hex screw water valves, metal dome pressure switch on porcelain coated top and cabinet.
i wish they would bring back true direct drive topload washers brand new in stores to sell i did laundry today i had set the washer to warm wash cold rinse did not even fill with warm water and i never know when my curent washer will pop fault code F3E3 when its already showing a bad control board fault code F0E4, i think my curent washer is a lemon i even gave up after alerting my mom that we should have the washer check by a tech. What will it take to make my mom realise we have a cheap washer and i think my mom back in 2021 when we bough or curent set my mom should of lisen to me when i told her sig about huebesch speed queensigh can not go back in time
They certainly should bring back the direct drive.
What did you mom say after you told her about the error codes and that it needs to be checked out by a repair man?
she said nothing and my mom is afraid of fire and in my honest opinion if my mom do not do anything about that now it will only get worst and sometime i fear as the washer fills for the main wash or rinse as it sense the load that the pressure of the water in the wash tub will make what hold the tub break and fall plus as you will see in the pic washer dryer are on the second floor and i do not went to imagine the damage that would do if a wash tub full of water was to fall it would break the celling and make a nasty mess and also when reaching the rinse extra power extra rinse cause a spray rinse before finalk rinse i hear the washer buzz before starting spray rinsing the clothes before the final rinse with softner8gSgdwa.jpeg
I am tempted to doubt the tub will just crack and leak, but it is not unheard of of VMWs exploding in spin.
I validate some of your mothers concerns and seek out either a Speed Queen washer or a used direct drive washer. The dryer I think can wait but the cold washing and error codes are clearly getting in the way of doing laundry as desired.
