Dryer comparasion
I don't specifically know Canadian Whirlpool/Inglis ... but:
1.  The first dryer pictured is older.
2.  The first dryer has a variable thermostat temp control ranging from air (heat off) to high.
3.  The second dryer seems to have only two temp choices -- heat (red) or air (green).  So, that makes the first dryer a little more deluxe.
4.  Both dryers have the same timer & cycle choices -- timed Perm Press/W-n-W, and timed "regular."  The choices of 1-Light, 2-Medium, 3/4 Heavy, & Ex-Heavy are not a moisture-sensor cycle, it's timed but without the minutes stated.  The difference between Perm Press & the "regular" cycle is length of the cool down (5 mins vs. 10 mins).
