Too funny!
It's really ironic that the topic of these dryer balls was posted...
There's an 8-day Home & Garden show going on in Milwaukee--This past Weekend, then today, Thurs, Fri, Sat, and Sun... Anyways, Hoover has a booth at the show and directly across from our booth is the "Dryer Magic" booth. Her demonstration is mesmerizing! Allow me to repeat parts of her demonstration (After all, I've seen it a hundred times so far...)
All dryer sheets are petrolium-based. The 'softness' is, in reality, the petroleum and other chemicals rubbing off onto our clothes. She points out the warnings on the side of all dryer sheet boxes--to the effect of "Do not use on children's clothing or bed wear that is labeled as 'flame resistant', as the dryer sheets will reduce the flame resistance."
The residue that dryer sheets give off can also mess with the heat sensor in the dryer--leaving a filmy coating on it, and it may not work properly. Same goes for the lint trap. A lot of times, if you pull the lint trap out and try to run water through it, you'll find you can't. Because, again, that residue has built up on the lint trap.
She takes a dryer sheet, pours a bit of water on it, and rubs it around in circles on a mirror. It's pretty interesting what comes off of it--a sudsy soapy sort-of residue. Apparently, you can also take a dryer sheet, and put it in, say a pan that you've cooked something like lasagna in--fill it with hot water, add a dryer sheet, and come back in an hour or two... It helps break down the burnt on cheese/sauce/grease... and makes cleanup a snap.
She then goes into some statistics about how many dryer fires happen per year as a result of that lint-trap not working properly (15,000).
Then there's the mysterious greasy spot that magically appeared on your article of clothing--that wasn't there when your clothes went into the laundry... Caused by the liquid fabric softener or the dryer sheet (again, look at the warning about spotting on your liquid fabric softener and dryer sheets).
The balls are made out of food-grade PVC, and after a few minutes in the dryer, they stop clunking around, and soften up. They "lift and separate" the clothes, and help more evenly re-distribute the heat (and can reduce drying time by up to 25%). This naturally reduces wrinkles and static...
The dryer balls are unscented, but most laundry soaps are... so there really isn't a need for any additional scent.
The hook: If you think about it, you can spend upwards of $100 dollars per year on fabric softeners-liquid and sheets. So, a $20 dollar investment will really save you money in the long run.
Needless to say, I am now the proud owner of... count 'em--2 sets of "Dryer Magic" balls, and I've been pleased with them so far!
~Fred
