dumbed down water temp
toploader1984
Feb 14, 2009
551
hello everybody, so i've had my frigidaire top loader for almost a year now and i have already adjusted the water to fill to the top row of holes since it ONLY filled up 3/4 of the way. the next problem i have (most modern machines have) is the stupid dumbed down water temp! AHHHHHH so annoying! when i select hot it switches back and forth from hot to cold, and when just hot water is on it is basically a trickle. when i do whites it literally takes 15 min just to fill the tub because of the flow restrictor. when i use warm water is it basically what tap cold is in the summer time, so.... once again the government is telling me what temp i have to wash my clothes in now. the government puts a regulation on a little hot water yet they DON'T put a regulation on cfl bulbs that contain mercury and is bad for our health..... (yes i have broke one before) ok anyways i needed to rant lol. so my question is... is it possible to maybe replace the water inlet/mixing valve with a part from an older model?
Workaround
There must be a workaround for this feature. The question is. Where does the switching logic exist? Where is the temperature being measured? Isn't there a thermister in the fill flume? What would happen if you disconnect it?
Malcolm
temp
hmm, well, in an older machine when you select warm isn't it 50/50 mixture of cold and hot? both full pressure? that would make sense to disconnect it somehow.....
In my front loader Duet, I added resitance to the themister that monitors water temp and did raise the wash temp a bit.  Not sure if it's impacting the water coming in or just triggering the built in heater.  Best bet is to look at the schematic for your machine.
