runningman
- Joined
- Nov 17, 2013
- Messages
- 4
Help!
I have a Dyson CR01 that has spent 5 years in a dry garage being stored.
Before being stored it was emptied of water & good working order. 6 months prior to storage it had had a service & the full drum unit replaced due to the contra rotation fault.
I've moved it into the new property & left it for 2 days before plugging it in.
Turns on as normal & starts a wash fine. After approx 5 minutes the door catch is ticking there is a judder noise and lights are flashing on the control panel an a beep is heard along with the control panel going faint saying "dyson 2 drums"
Start will not restart the machine & the only way out is to turn off leave for a min then switch on quickly pressing cancel. The program cancels & the machine drains correctly - all is good again.
The machine works fine on a rinse & spin cycle.
I've read on this forum how to put it into diagnostic to see stats & step through the program. Its after 3 presses (4th phase of a wash) that its stops working.
Any thoughts?
I tried the dyson helpline only to get a "we no longer support this machine". I'm half tempted to book a service for the vacuum & then bribe the engineer to look at the washing machine
Any thoughts?
