aviator74
Member
Hello.
I'm hoping that some of you folks that are more knowledgeable than myself can help me out again. I have a early 80's Eaton's Viking dryer and washer. These are GE units private labeled for the Timothy Eaton's department stores in Canada. I tried to do some laundry in the washer and discovered an issue. The washer will not fill or agitate in any cycle, but it will fill rinse water, spin, and drain in all cycles. This lead me to believe the fill valves and other systems are working, but that the timer may have an issue. I know full well, unfortunately, that parts are getting scarce. Are there any ideas about the cause of the problem, and suggested solutions? I have included pictures of the timer, as I know there are a few versions. Thank you.
