Early 80's White Westinghouse Spiral Ramp Agitator
scrubflex
May 12, 2008
1,084
bronx, new york
Danmantn, if you're still looking modified another White Westinghouse agitator------the "more improved" deep ramp agitator is for sell on ebay. The color is white instead of blue. This one has the "ribbed" surface to create added drag from the agitation thus (extra double scrub) stronger downward pulling power. Check it out.
Harry
http://www.ebay.com/itm/5300101523-...OR-ASSEMBLY-/291510203014?hash=item43df5cb286
Danman, have you consider replacing the long screw rod and attach an actual White Westinghouse agitator shaft to the Speed Queen agitator drive bell? The screw rod can and will rust. BTW, when are you going to make more videos of the White WestingQueen? Videos of Mini...Small...and Large setting loads.
