vacerator
Matt, a housing plan concept which has returned in some locales. Chicago suburbs, and some Florida places have back ally's/streets.
Server sporadic this morning.
My home, according to the Deed that I have, was made in 1940.Matt, a housing plan concept which has returned in some locales. Chicago suburbs, and some Florida places have back ally's/streets.
there are some reasonably priced field detectors on amazon.....I actually don't mind having those new meters installed.
My bills are still accurate.
And it hasn't affected, as far as I know, with my life.
And it better not.
I would tend to think that any locations of the underground utility services were determined at the original locations via measurements from the home's exterior walls.My home is an 1850sf brick and block rancher, which I was told was moved several miles to the elevated lot it sits on. How one moves an eggshell that far without a single crack I don't know... Much less pour a new slab and get plumbing (2 iron bathtubs in original tiled alcoves!) aligned correctly. I mean, they CAN'T have yanked the slab up with the house, right? I looked up the city aerial photographs, lo and behold, empty lot in 1982, house, pool, fence and trees there in 1986. There's also the matter of the gas lines and flues for a furnace and water heater, on a cul-de-sac with no gas main. Found the clincher when I renovated the hall bath, an "ok to close" tag from the electrical inspection dated 1967.
But within a eighth of an inch or so? I mean, I can't even cut a hole in a sheet of drywall correctly most of the time... I probably waste 30% of extra material in any particular job!I would tend to think that any locations of the underground utility services were determined at the original locations via measurements from the home's exterior walls.
Confirmation of those measurements would be clear after the move.
To me that makes sense, and common sense.
But what do I know?
