Hi Melvin and John - thanks so much for the insight. Melvin, that spring definitely didn't come out of the old seal. I took the bearings and seals out quite sometime before I put the new ones in and had cleaned up the floor several times in between. I'm quite certain it came out of the seal for the upper bearing then. If you don't mind me asking, does it just sit on the outside of that lip and is there anything you can see holding it in place like a groove or another lip? From looking from the top of the seal does it just sit near the top or farther down near the bottom?
I'll attempt to reseat it but I doubt I'll be able to get it in with the bearing in the way. If I cant, as John suggested I'll just leave it and see what happens.
